2 Pages<12
fairbank56
#11 Posted : Wednesday, February 19, 2014 9:14:02 AM(UTC)
fairbank56
Groups: Expert
Ah, so it is a Canadian model. Ok, anyway, unplug the dryer, open the control panel to gain access to the timer. Disconnect the wire on the BK terminal that goes to the timer motor. Disconnect the blue wire on the BU terminal that goes down to the drive motor and connect it to the BK terminal. Plug dryer back in and start it. If it doesn't run this way, the problem is not the timer.
Eric
cecildow
#12 Posted : Wednesday, February 19, 2014 10:01:22 AM(UTC)
cecildow
Nope didnt start, I will started over again and double checked the other things again, anything else that I could check. Thanks
fairbank56
#13 Posted : Wednesday, February 19, 2014 10:40:46 AM(UTC)
fairbank56
Groups: Expert
Did you check for power at the receptacle? Should have 120vac between neutral and each hot leg and 240vac between hot legs. May be open neutral? Check power cord connection block.
Eric
cecildow
#14 Posted : Wednesday, February 19, 2014 11:12:00 AM(UTC)
cecildow
Ya getting power from the fuse box to the inside of the dryer. when checking the other parts with my ohm meter im getting 000 everywhere except the thermostat, I get 000 from the 2 red wires but i get 116 from the 2 smaller blue wires, but there is continuity between the terminals cause the numbers on the ohm meter goes to 116. And on the door switch one side I get 000 then open the door and i get 36, I get the same reading from the other wire on the door switch aswell. Using a power cord from an old extention cord I hooked one side to the blue wire on the timer and the other to the white wire from the start button and plugged it in and the motor runs so I know its not that. Thaks
cecildow
#15 Posted : Friday, February 21, 2014 3:20:15 AM(UTC)
cecildow
A loose white wire in the outlet was the problem, Thanks for all the help
LG LMV1680ST Microwave Door Switches (Microwave Repair)
by ctalbert150 6/13/2024 7:19:37 AM(UTC)
Door Switch Help With Samsung Microwave Model ME21M706BAS (Microwave Repair)
by clagrow 5/2/2024 6:28:45 AM(UTC)
Kitchenaid (Whirlpool) Microwave door switches (Microwave Repair)
by ForumUser1 1/11/2024 1:11:07 PM(UTC)
Frigidaire Refrigerator LGHT1846QP1 - door switch and cabinet cooling (Refrigerator & Freezer Repair)
by BJPrice 10/26/2020 5:28:12 AM(UTC)
Maytag MVWC4658W2 Door switch? Will drain but not spin. (Washer Repair)
by JimAlbr 6/4/2020 5:49:53 PM(UTC)
Dryer keeps blowing the DOOR SWITCH?!?! (Dryer Repair)
by ppipowerclass 12/3/2017 12:54:14 PM(UTC)
Door switch (Dryer Repair)
by Hoglover 4/7/2017 2:37:33 PM(UTC)
Whirlpool Door Switch Replacement- lost power to microwave (Microwave Repair)
by jk071604 3/23/2017 4:55:46 AM(UTC)
door switch (Dryer Repair)
by Cole B. 8/28/2016 10:26:07 AM(UTC)
How to remove the door switch (part #AP4442085) (Refrigerator & Freezer Repair)
by rannug 4/20/2016 10:12:10 AM(UTC)
wiring for maytag door switch (Dryer Repair)
by macjane94 5/29/2015 10:25:15 AM(UTC)
Door switches not operating properly (Microwave Repair)
by restlesssailor 4/19/2015 12:21:54 PM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
How do I disconnect door switch? (Dryer Repair)
by ocampon 12/12/2014 3:18:51 PM(UTC)
Can't put the freezer door switch back! (Refrigerator & Freezer Repair)
by bzk 5/13/2014 5:22:07 PM(UTC)
2 Pages<12
