Just wondering if the door switch is bad will this also cause the light not to work aswell? Thanks
Groups: Expert
Can't tell you without knowing the model number.
Eric
Groups: Expert
That's not the model number. Should be a label with model number and serial number. May be under lid on panel rim.
Eric
Groups: Expert
Still no good. If model number starts with 110. then it's made by Whirlpool but I already tried 110.8846291 and it doesn't come up. Is this a Canadian model? Usually,there's 11 numbers.
Eric
Only other number on the tag is a ser#, I have tested everyting that I could and all is good but dont know how to test the timer. Is there a way to bypass the timer to see if this may be the problem? Its a Kenmore 60 series dryer. Thanks
Groups: Expert
Can't help without the model number unless you can post hi-res photo of the wiring diagram. Should be inside the control panel or possibly inside the cabinet somewhere. Lamp does usually come off the door switch. Is the non operating lamp the only problem your having?
Eric
Actually the dryer does not do anything so I was trying to check to most common thing that goes bad. I checked the door switch,thermal fuse,thermostat,start switch,breaker,the wall plug,the power cord,the motor,with a volt and ohm meter, I just dont know how to test the timer. here is a pic of the wiring and the model number. Thanks cecildow attached the following image(s):
A pic of the timer. Thanks cecildow attached the following image(s):
