thanks joe i went and got some real thin adapters for my meter i will keep you posted
Originally Posted by: gregaguilar  thanks joe i went and got some real thin adapters for my meter i will keep you posted Greg, That's even better, didn't really want you to go through the extra expense, but the "Pin Point" leads would be best.
joe believe or not it was the motor that was bad even though i ohmed it out it checked good and whenm i went back to check mcu cc i turned unit on and it started into spin then it winded down with a thump and you could hear that motor no bueno that ohmeter is really not that reliable thanks joe i really appreciate your help anyway
Originally Posted by: gregaguilar  joe believe or not it was the motor that was bad even though i ohmed it out it checked good and whenm i went back to check mcu cc i turned unit on and it started into spin then it winded down with a thump and you could hear that motor no bueno that ohmeter is really not that reliable thanks joe i really appreciate your help anyway Greg, Great job. Glad you were able to figure it out. You should be up and running soon. Meters can be tricky, and you have to take care of them, keep them calibrated and in good working order. Again, Great job and Thanks
