207 Pages«<193194195196197>»
zukkev
#1941 Posted : Saturday, August 31, 2013 8:21:51 AM(UTC)
zukkev
Originally Posted by: richappy Go to Quoted Post
Did you replace the defrost thermostat 5303918214
Yes, that is part of the defrost heater assy... I have ordered another timer, but in the meantime it appears to be working normally...Fridge temp at 35*F, freezer at 0*F---compressor cycling...
Toddjulie01
#1942 Posted : Sunday, September 1, 2013 6:23:02 PM(UTC)
Toddjulie01
I have just ordered a new defrost timer for my kenmore model #10650517000 and I can't seem to find a tech sheet to know where the black wire goes on what terminal pin. I have watched several videos but have not found a definite answer for this model. Any help would be appreciated.
#1943 Posted : Monday, September 2, 2013 1:21:19 AM(UTC)
All the modern fridg's use the standard connection. Put the wire in the middle pin of the three isolated pins.
fredpeterson543
#1944 Posted : Wednesday, September 4, 2013 10:14:40 PM(UTC)
fredpeterson543
Hello Friend
solve it please
my refrigerator doesn't get my food cold enough. it's cool but not cold. my kitchen has an uneven floor does this affect temperature. my freezer works fine.
There is my Refrigerator IMAGE.
UserPostedImage
____________________________________________________________
Web Designing Companies in Delhi
zephlew
#1945 Posted : Saturday, November 9, 2013 4:13:39 PM(UTC)
zephlew
Trying to determine if my Hotpoint has a "defrost timer" and where it is.
Model hsm25gftsa. fridge area warm. frost on back panel.
I have had to unload and defrost it manually twice now. Quite a while between times.
First post on the thread says try "defrost timer" first.
mgalland
#1946 Posted: : Tuesday, November 19, 2013 10:55:02 AM(UTC)
mgalland
I have a GE side by side that is fine on freezer side, but only cools to about 45 on the frige side. It also seems to run almost all the time. I just found this site and will check the defroster this pm. Here is model #, GSS22JEMD WW, Serial #VD205604.
e30kawi
#1947 Posted : Tuesday, January 14, 2014 5:24:40 PM(UTC)
e30kawi
I have this same issue addressed in this thread. I am just not sure where my problem may be. I looked, I don't see any frost or snow at the back of my freezer. But after I plugged the unit back in after cleaning underneath it and the coils, it seemed to cool right down. Its been a few hours since plugging it back in and it does not seem to be as cool or as responsive as it was right after plugging it in. While it is better, its not as it should be. Is it the damper control/fan from the freezer?
#1948 Posted : Wednesday, January 15, 2014 2:37:30 AM(UTC)
Remove the back freezer panel and check the frost pattern, should be light frost all over.
e30kawi
#1949 Posted : Wednesday, January 15, 2014 3:25:06 PM(UTC)
e30kawi
And if there is front all over? Does that mean I need a new thermostat?
RUsum1
#1950 Posted : Monday, January 20, 2014 1:04:37 AM(UTC)
RUsum1
I still can't fix my stupid fridge. I have tried several different parts and nothing solves it. My defrost heater works. I got a new defrost timer even though I think my old one was fine. I got a new defrost thermostat (not really sure if the old one worked or not).
I even got a new evaporator fan motor because I didn't think that was spinning in order to send the cold air to the fridge but the one I got doesn't match the one I wanted to replace. Then the part that the fan motor connects to started to melt one random day so I removed it completely for the time being.
What is this part?
Picture 1 is of the part while it's put together. Picture 2 shows the fan motor disconnected from the part that I actually need.
I was told that part AP4700070 would replace my fan motor but it does not. The connections are not the same. My actual part number is 241537301 but that is not interchangeable
serial number of my fridge is 4a73622489
It is a Kenmore Elite 253.74223700 Fridge
RUsum1 attached the following image(s):
Guest (8)
Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by mrhoagie 11/3/2012 1:46:58 PM(UTC)
Another Freezer is fine, refrigerator is too warm. (Refrigerator & Freezer Repair)
by rzeune 10/7/2010 9:19:39 AM(UTC)
by allemich 4/19/2009 8:02:07 PM(UTC)
