cullough22
#1 Posted : Saturday, January 11, 2014 6:35:17 AM(UTC)
cullough22
kenmore oven model# 79096112401 will not heat up everything else works is it the clock control panel
#2 Posted : Saturday, January 11, 2014 8:24:19 AM(UTC)
Yes it is probably the clock/control board but I would check thet the wires to the control board and the elements are OK.
Also I am assuming that the oven stays in preheat and never comes ready.
If it does show that it is ready then it could be the oven sensor.
Part number: AP4587739
You may also need a new overlay sometimes they get damaged trying to remove them.
Part number: AP3771827
frigidaire oven wont heat after self clean (Oven Repair (including Ranges and Cooktops))
by chalooch101 10/14/2019 5:04:21 AM(UTC)
Oven wont heat or broil (Oven Repair (including Ranges and Cooktops))
by artpell 12/25/2014 1:04:08 PM(UTC)
GE Profile electric single wall oven wont heat (Oven Repair (including Ranges and Cooktops))
by PRWATTS 8/28/2014 8:31:49 PM(UTC)
Oven wont heat (Oven Repair (including Ranges and Cooktops))
by txtrevor 4/4/2014 8:47:16 AM(UTC)
Oven wont Heat up (Oven Repair (including Ranges and Cooktops))
by belliemom 2/28/2014 5:20:18 PM(UTC)
Kitchenaid Gas oven wont heat up (Oven Repair (including Ranges and Cooktops))
by Travelguy 1/1/2014 5:52:03 PM(UTC)
Oven wont heat up (Oven Repair (including Ranges and Cooktops))
by shellyrodriguez 11/23/2013 8:55:12 AM(UTC)
sears/kenmore elements/oven wont heat (Oven Repair (including Ranges and Cooktops))
by KERMITT454 7/19/2013 4:51:23 PM(UTC)
Maytag Gemini Oven wont heat (Oven Repair (including Ranges and Cooktops))
by Stevewk 5/15/2013 3:12:12 PM(UTC)
Frigidaire Oven Wont Heat Up (Oven Repair (including Ranges and Cooktops))
by GHog 5/7/2013 3:18:52 PM(UTC)
ge wall oven wont heat up (Oven Repair (including Ranges and Cooktops))
by henson1166 1/5/2013 5:08:07 AM(UTC)
Roper electric oven wont heat (Oven Repair (including Ranges and Cooktops))
by fireguy 12/20/2012 7:43:38 PM(UTC)
oven wont heat burners work (Oven Repair (including Ranges and Cooktops))
by michellem 10/2/2012 3:59:41 AM(UTC)
Xfe361lvb Oven Wont Heat,no Error Codes (Oven Repair (including Ranges and Cooktops))
by awvufan76 9/12/2012 10:10:51 AM(UTC)
lights come on oven wont heat up (Oven Repair (including Ranges and Cooktops))
by fxe81hd 5/3/2012 12:43:28 PM(UTC)
