Hattrix
#1 Posted : Saturday, December 14, 2013 5:41:08 PM(UTC)
Hattrix
Whirlpool Dryer Model WED5100VQ1
My dryer started to randomly not heat up until it stopped heating up more than not. I did some research and used a multimeter on 4 different parts to check for continuity but couldn't definitively tell if there was a problem SO, I bought all four pieces and replaced them all. It STILL isn't heating up 100% of the time.
These are the pieces that I bought and replaced:
Thermal Fuse
Heating Element Assembly
High Limit Thermostat
Cycling Thermostat
What did I miss?
Help!
:confused:
Dmalone1949@gmail.com
#2 Posted : Sunday, December 15, 2013 10:37:02 AM(UTC)
Try replacing the gas valve coils.
There are 2 small parts (cheap) that sit on the control unit at the incoming gas pipe at its connection to the burner area. Easy to replace. Check this excellent video out: Whirlpool 279834 Dryer Gas Valve Coil Kit - AppliancePartsPros.com
Hattrix
#3 Posted : Sunday, December 15, 2013 10:55:00 AM(UTC)
Hattrix
It's an electric dryer.
Hattrix
#4 Posted : Monday, January 6, 2014 1:09:21 PM(UTC)
Hattrix
Bump .... the issue still remains.
Dryer heats on HIGH more often than any other setting, but it's not always heating every time.
Help!
fairbank56
#5 Posted : Monday, January 6, 2014 2:22:25 PM(UTC)
fairbank56
Groups: Expert
The thermal fuse is in the motor circuit, not the heating circuit. There is a thermall cutoff in the heat circuit but if it was blown, you wouldn't get any heat. Problem could be timer contact or motor switch.
Eric
Hattrix
#6 Posted : Monday, January 6, 2014 5:46:24 PM(UTC)
Hattrix
Eric
Thanks Eric. I'll look into the Timer and/or Motor Switch.
Guest (4)
