Whirlpool Dryer Model WED5100VQ1My dryer started to randomly not heat up until it stopped heating up more than not. I did some research and used a multimeter on 4 different parts to check for continuity but couldn't definitively tell if there was a problem SO, I bought all four pieces and replaced them all. It STILL isn't heating up 100% of the time. These are the pieces that I bought and replaced: Thermal Fuse Heating Element Assembly High Limit Thermostat Cycling Thermostat What did I miss? Help! :confused:
Originally Posted by: Dmalone1949@gmail.com  It's an electric dryer.
Bump .... the issue still remains.
Dryer heats on HIGH more often than any other setting, but it's not always heating every time.
Help!
Groups: Expert
The thermal fuse is in the motor circuit, not the heating circuit. There is a thermall cutoff in the heat circuit but if it was blown, you wouldn't get any heat. Problem could be timer contact or motor switch.
Eric
Originally Posted by: fairbank56  The thermal fuse is in the motor circuit, not the heating circuit. There is a thermall cutoff in the heat circuit but if it was blown, you wouldn't get any heat. Problem could be timer contact or motor switch.
Eric Thanks Eric. I'll look into the Timer and/or Motor Switch.
