Takes 3-5 'spins' to get it drained and dried properly before sending it to the dryer. Spins slowly compared to how it should. Sometimes it doesn't spin at all (you have to start it by hand).
Is this fixable/worth fixing? Any help is greatly appreciated.
Groups: Expert
Thank you so much Eric. Originally Posted by: fairbank56  Should be hard to do. Did you mean should not be hard to do?
Groups: Expert
No, it should be hard to rotate the clutch band within the clutch hub with just using your finger.
Eric
