TheDude
#1 Posted : Monday, December 30, 2013 11:53:55 PM(UTC)
TheDude
Takes 3-5 'spins' to get it drained and dried properly before sending it to the dryer. Spins slowly compared to how it should. Sometimes it doesn't spin at all (you have to start it by hand).
Is this fixable/worth fixing? Any help is greatly appreciated.
fairbank56
#2 Posted : Tuesday, December 31, 2013 4:55:01 AM(UTC)
fairbank56
Groups: Expert
Definitely worth fixing. Slow spin is usually caused by a worn clutch but can also be a worn drive block or failing motor coupler. Another possibility is something in the pump causing the motor to run slowly. You can pull the pump off the motor and try spin to rule that out. Pull the gearcase to get to the clutch. Hold clutch hub and try to rotate clutch band with your finger. Should be hard to do. Remove agitator to inspect top of drive block. Remove motor to inspect motor coupler.
Whirlpool 285785 Clutch Assembly - AppliancePartsPros.com
Whirlpool 389140 Washer Drive Block - AppliancePartsPros.com
Whirlpool 285753A Whirlpool Direct Drive Washer Motor Coupling - AppliancePartsPros.com
Eric
TheDude
#3 Posted : Tuesday, December 31, 2013 10:14:36 PM(UTC)
TheDude
Thank you so much Eric.
Did you mean should not be hard to do?
fairbank56
#4 Posted : Wednesday, January 1, 2014 4:13:28 AM(UTC)
fairbank56
Groups: Expert
No, it should be hard to rotate the clutch band within the clutch hub with just using your finger.
Eric
