jgoodman28
#1 Posted : Friday, May 1, 2009 6:44:54 AM(UTC)
jgoodman28
I have an electrict dryer and it will heat up for about twenty and the whole dryer will shut off. And I cant restart until it sits for a few minutes. I wanted to ask and get help before I start guessing and buying parts I dont neet
#2 Posted : Friday, May 1, 2009 12:00:48 PM(UTC)
Sounds like the motor has gone bad. I would take the dryer apart right after it stopped and check if the motor is hot. If it is then it has to be replaced.
Here are the breakdown diagrams and Replacement parts for FRG GLER341CC0 | AppliancePartsPros.com
jgoodman28
#3 Posted : Sunday, May 3, 2009 9:37:39 AM(UTC)
jgoodman28
thanks for the input but is there any way to tell for sure that the motor is bad or anything else to check before spending the money for a new motor just wondering hoping to save as much money as possible. Thanks again for the help.
mani
#4 Posted : Sunday, May 3, 2009 4:48:47 PM(UTC)
mani
you should change the motor,it will be fine
jgoodman28
#5 Posted : Thursday, May 7, 2009 4:52:55 PM(UTC)
jgoodman28
I took the dryer apart and gave it a good cleaning and now the motor is acting fine but now the dryer will not get hot. Are the heating coils bad or is there something else to look for that might be causing.
#6 Posted : Thursday, May 7, 2009 4:55:56 PM(UTC)
It could be a bad coils, a bad thermostats or a bad wires. You have to have a simple multimeter to perform the troubleshooting.
#7 Posted : Friday, May 8, 2009 2:07:25 AM(UTC)
Here is a wiring diagram
http://manuals.frigidaire.com/p...df/Webster/131850600.pdf
The one in ite parts breakdown is pretty blurry.
I would also suspect the centrifugal switches on the motor.
If the one for heat does not close when the motor gets close to operating speed, you will not have heat.
Also if the one for switching out the start winding does not switch over, the start winding will not disconnect and this will cause the motor to overheat.
Could be the centrifugal mechanism is not operating correctly.
One way to check would be to:
Unplug the unit
Short the two wires that go to the heater centrifugal switch together.
Tape then up so they cannot short to anything else.
May also have to tape them to something else to make sure they do not vibrate and get into the motor.
Plug the unit in and give it a try
If you now have heat then that is your problem.
Note: This is just for testing.
Do not run the unit very long like this as the heater will now run without the motor turning. If the motor does not turn for some reason the machine will over heat and hopefully blow the thermal fuse.
Guest (4)
Frigidaire Gas Dryer Shuts Off After Less Than A Minute Run Time (Dryer Repair)
by hooter726 10/23/2018 11:54:54 AM(UTC)
Samsung dryer shuts off after 3 minutes (Dryer Repair)
by Mort184 8/2/2017 3:41:15 PM(UTC)
GE Dryer shuts off mid cycle (Dryer Repair)
by nfdmedic 11/14/2016 4:49:22 PM(UTC)
GE dryer shuts off in middle of drying cycle (Dryer Repair)
by archieandveronica@msn,com 4/19/2016 12:23:50 PM(UTC)
GE Electric Dryer Shuts Off Mid-Cycle (Dryer Repair)
by Dynocon 10/22/2015 5:20:00 PM(UTC)
WP Dryer shuts off after 2 minutes (Dryer Repair)
by 44Rick44 9/22/2015 2:47:34 PM(UTC)
Dryer shuts off early (Dryer Repair)
by supertweet 7/2/2015 2:12:17 PM(UTC)
Dryer shuts off after 10 minutes in auto (Dryer Repair)
by loveg65 4/12/2015 12:32:14 PM(UTC)
Dryer shuts off after a couple of minutes (Dryer Repair)
by mrsteelxx 1/28/2015 7:05:23 AM(UTC)
dryer shuts off after a couple minutes (Dryer Repair)
by TowerDSue 8/25/2014 12:40:40 PM(UTC)
gas dryer shuts off after a few seconds (Dryer Repair)
by AAP2014 7/26/2014 5:18:49 PM(UTC)
Dryer shuts off intermitently (Dryer Repair)
by mercosur67 4/16/2014 2:29:27 PM(UTC)
by Abartman 8/14/2013 12:10:52 PM(UTC)
Kenmore 80 series Dryer shuts off intermittently (Dryer Repair)
by fenster88 5/15/2013 9:35:01 AM(UTC)
Dryer shuts off (Dryer Repair)
by Pipsqueke 1/4/2013 5:47:10 PM(UTC)
