102991
#1 Posted : Wednesday, April 22, 2009 8:42:15 AM(UTC)
102991
Would anyone happen to know where the Adaptive Defrost Board is located in my Jenn Air refrigerator? I can't seem to find any info as to location. Thanks.
kooler
#2 Posted : Wednesday, April 22, 2009 9:14:21 AM(UTC)
kooler
Just click on the model number in your post and pics of your fridge will open; click on window 2 (controls) and locate item 13 which will show location of the adaptive defrost control... cheers
102991
#3 Posted : Wednesday, April 22, 2009 9:21:56 AM(UTC)
102991
Thanks Kooler. I guess I just wasn't looking hard enough.....I appreciate your input.
ilb09
#4 Posted : Friday, May 1, 2009 11:39:48 AM(UTC)
ilb09
I have the same question. I've ordered/received the part but am still searching for how to remove the overhead covers and replace the part without breaking everything.
Any help out there for us? Gene?
Les Bowles
102991
#5 Posted : Friday, May 1, 2009 4:45:49 PM(UTC)
102991
You will have to remove a couple of screws behind and to the left and right of the temp control levers in order to remove the plastic trim. The actual Adaptive Control Board housing has clips on it. Take it slow with a flashlight and it should pop right off. By the way, the ACB took care of the problem and the fridge (and freezer) work like a champ! I did find what appears to be
a deterioration of the plastic coating on the old board and I'm wondering if it was just shorting itself out???? Anyway, good luck. It's a piece of cake.....
ilb09
#6 Posted : Saturday, May 2, 2009 7:10:34 AM(UTC)
ilb09
Thanks! I looked through some of the other posts awhile later and found a similar description. You're right...it's not difficult...but we should add that it's necessary to unplug the refer. The board is still drawing current even after turning off the unit. I've had some recurring icing issues on the condensor coil that I thought might be a faulty heater element but after reading other posts, it may have been a faulty ACB causing it all. My old one would start buzzing (bad relay box on the board) and would not stop unless I unplugged/plugged the refer. I was able to get it out without issues and my old one was in a pocket in the back right corner of that housing. It wasn't attached to anything but just laying in the corner space. A simple case of plug and play. I've read that others are in a different style of plastic box and are held in with screws. ?? It's all working great and I'll see if my condensor icing problem returns or not.
Thanks for your help...LesUserPostedImage
Refrigerator Compressor Starting With Failed Start Relay??? How Can This Be? (Refrigerator & Freezer Repair)
by AppliancePartsAmateur 7/1/2024 5:18:48 PM(UTC)
GTS16DTNKRWW Refrigerator - Intermittent Operation (Refrigerator & Freezer Repair)
by seocom 6/22/2024 6:51:32 AM(UTC)
GE refrigerator/freezer side by side (Refrigerator & Freezer Repair)
by Pdynamo 6/20/2024 6:20:43 PM(UTC)
Kitchenaid refrigerator and freezer intermittently to warm (Refrigerator & Freezer Repair)
by Guest 6/18/2024 12:12:20 PM(UTC)
Whirpool WRF535SMBM Refrigerator (Refrigerator & Freezer Repair)
by goclones 6/16/2024 8:15:11 AM(UTC)
Samsung Refrigerator Pantry Drawer Support #SAM-DA61-03174A (Refrigerator & Freezer Repair)
by joecoliphant 6/15/2024 8:12:03 AM(UTC)
Ice behind fan pannels in refrigerator and fan not working (Refrigerator & Freezer Repair)
by Mark7604 6/9/2024 6:43:14 AM(UTC)
GTR22HBTARBB water leak to bottom refrigerator (Refrigerator & Freezer Repair)
by wilsonjiaho 6/8/2024 4:24:50 PM(UTC)
LG Refrigerator - Makes ice, but won't dispense ice nor water (Refrigerator & Freezer Repair)
by teamfindley 5/28/2024 7:48:32 PM(UTC)
samsung fd refrigerator (Appliance Repair Companies - East of the Mississip)
by gale reid 5/28/2024 3:17:33 PM(UTC)
Cold-Coldest setting on meat drawer on GE GNE25j refrigerator (Refrigerator & Freezer Repair)
by Guest 5/23/2024 11:20:53 AM(UTC)
Refrigerator freezer (freezer is above refigerator,) (Refrigerator & Freezer Repair)
by cwillman 5/16/2024 12:29:58 PM(UTC)
GE Side by Side Refrigerator Model GSS25IYNXHFS dim LED lights (Refrigerator & Freezer Repair)
by jhauter 5/15/2024 4:30:46 AM(UTC)
Refrigerator Ice (Refrigerator & Freezer Repair)
by Guest 5/9/2024 7:00:37 AM(UTC)
GE refrigerator Ice machine not working. (Refrigerator & Freezer Repair)
by Don718 5/6/2024 11:45:46 AM(UTC)
