blackbeard1298
#1 Posted : 16 years ago
blackbeard1298
My G.E. microwave stopped heating last week and decided to check door switches, transformer, thermal protectors, hv capacitor, and hv diode. everything checked out except for the diode. It showed infinite readings when checked both ways, which should mean that the diode is open. So I ordered a new diode from you guys, part no. WB27X10597 and decided to check it for resistance before replacing it. And the new diode shows infinite readings when checked both ways. Do you think that the new diode is open as well?
Thanks,
John
applianceman
#2 Posted : 16 years ago
applianceman
Diodes on microwaves are open one-way and a very high resistance the other. So if your meter isn’t set high enough it will read as if it were open. Some ohmmeters do not have a high enough scale to check diodes. I have owned a few ohmmeters would not check microwave diodes. But it’s ok you need to replace it anyways along with you magnetron tube. Microwave Repair Guide
Microwave does not Heat Food (Microwave Repair)
by newatappliancerepair 8 years ago
Microwave does not heat (Microwave Repair)
by flynkites 12 years ago
Microwave does not heat...buzzing sound (Microwave Repair)
by bnhmiles 13 years ago
Whirlpool Microwave Does Not Heat (Microwave Repair)
by FixItManTim 14 years ago
microwave does not heat (Microwave Repair)
by suzzan 14 years ago
GE Profile Microwave does not heat any more (Microwave Repair)
by dealmaster 14 years ago
my microwave does not heat (Microwave Repair)
by videomandw 15 years ago
ge microwave does not heat, everything else works (Microwave Repair)
by shaunshaw 15 years ago
by Alex1977 15 years ago
Kenmore microwave does not heat (Microwave Repair)
by srikki9 16 years ago
Microwave does not heat up. (Microwave Repair)
by Aliens1 16 years ago
microwave does not heat, smells like its burning and buzzes (Microwave Repair)
by doogie48084 16 years ago
Jenn Air Microwave does not heat (Microwave Repair)
by SpacemonkeyR 16 years ago
by Kerryi 17 years ago
by Bob Shuler 17 years ago
