2 Pages<12
melavid
#11 Posted : Wednesday, November 20, 2013 5:47:27 PM(UTC)
melavid
I have tested the power from the wall it is what is was supposed to be, tested the thermal fuse and the high limit thermostat, even heated it to see if it clicked off at the temperature listed and it does. The last thing I haven't checked is the thermistor. and I don't know if it is worth replacing the Electronic control if it happens to be that . :mad: :confused:
Appliance Ninja
#12 Posted : Wednesday, November 20, 2013 5:59:11 PM(UTC)
Appliance Ninja
On the back of the main control is a large relay that has a large red and a large black wire connected to it. Remove the black wire and tape it off. Then, start the dryer in a heat cycle and test from the terminal the black wire was on to ground, looking for 120 VAC. If you do not read that voltage, the control is indeed faulty. If that is the case, the control is available at the link below. Let me know what you find.
Frigidaire 134557200 Control Board - AppliancePartsPros.com
Cafe Dishwasher little to no heat, not cleaning dishes well. (Dishwasher Repair)
by Jtaylor20 5/16/2024 10:15:38 AM(UTC)
Frigidaire gas dryer runs but no heat (Dryer Repair)
by Guest 3/16/2024 11:27:14 AM(UTC)
no heat from oven or broiler (Oven Repair (including Ranges and Cooktops))
by lennyag 1/5/2024 1:41:07 PM(UTC)
Dryer loud squeaking and no heat (Dryer Repair)
by hackerfam 11/2/2023 10:52:15 AM(UTC)
LG Dryer DLE2301R No Heat (Dryer Repair)
by mhess01 10/19/2023 4:56:37 PM(UTC)
No heat when assembled (Dryer Repair)
by Guest 8/16/2023 3:44:03 AM(UTC)
whirlpool PN# W10339417; no heating after replacing element (Oven Repair (including Ranges and Cooktops))
by Guest 7/13/2023 12:27:07 PM(UTC)
Whirlpool Duet Electric dryer - no heat (Dryer Repair)
by ShawnDS24 2/25/2023 9:08:24 AM(UTC)
No heat, (Dryer Repair)
by tseibring 1/8/2023 7:57:44 AM(UTC)
Brand New LG gas dryer , GAS code, no heat (Dryer Repair)
by lglad 11/24/2022 7:24:02 PM(UTC)
Gas Dryer GE GFDS355GL0MS No Heat. Ignitor is good E11 error. (Dryer Repair)
by jim.starzynski@gmail.com 7/5/2022 6:35:29 PM(UTC)
Dryer starts, does not stop, no heat (Dryer Repair)
by Guest 6/28/2022 11:03:33 AM(UTC)
Samsung Electric Range-No Heat (Oven Repair (including Ranges and Cooktops))
by Jimh64 6/27/2022 8:39:17 AM(UTC)
Samsung Dryer DV448AEP/XAC - no heat (Dryer Repair)
by mgmjtech 5/18/2022 8:22:27 PM(UTC)
heeat turns on no heat comming up through floor register (Heating, Ventilation, and Air Conditioning (HVAC))
by Guest 2/6/2022 2:57:49 PM(UTC)
2 Pages<12
