kb5ynf
#1 Posted : Wednesday, November 20, 2013 2:14:40 PM(UTC)
kb5ynf
My oven won't heat, bake or broil... no error codes. I changed the bake element, but still doesn't work. Any recommendations on what else to check or could cause this?
When I start a bake cycle, I hear an audible click within the oven, as normal, but the element doesn't heat.
Thanks,
Jack
Appliance Ninja
#2 Posted : Wednesday, November 20, 2013 2:22:24 PM(UTC)
Appliance Ninja
Number 119 in the picture below is a thermal fuse. It has likely opened. There is a red button on top of that fuse that will reset when pushed in. That fuse is mounted on the back of the oven and the access panel (number 71) will need to be removed to access it. Of course, the oven will need to be pulled out for access. Let me know what you find!
Appliance Ninja attached the following image(s):
kb5ynf
#3 Posted : Wednesday, November 20, 2013 2:28:44 PM(UTC)
kb5ynf
Ninja, thanks for the quick response. I'll give that a shot.
Regards,
Jack
Appliance Ninja
#4 Posted : Wednesday, November 20, 2013 2:30:51 PM(UTC)
Appliance Ninja
Sounds good, keep me posted!
kb5ynf
#5 Posted : Wednesday, November 20, 2013 4:22:39 PM(UTC)
kb5ynf
Well, you were right. That fixed it! Thank you very much!
Appliance Ninja
#6 Posted : Wednesday, November 20, 2013 4:26:59 PM(UTC)
Appliance Ninja
That is great news, very well done! Glad it was nothing major. Have a great evening!
Guest (5)
Double Oven Won't Heat Back Up After Opening (Oven Repair (including Ranges and Cooktops))
by lamoureux.adam@hotmail.com 12/13/2020 11:44:10 AM(UTC)
Lower GE wall oven won't heat up (Oven Repair (including Ranges and Cooktops))
by scalpeldoc 2/6/2019 11:56:18 AM(UTC)
oven won't heat, replaced element seems to have caused more problems (Oven Repair (including Ranges and Cooktops))
by kepu 1/8/2019 10:48:17 AM(UTC)
KitchenAid Electric Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by frosini 10/1/2018 7:23:00 AM(UTC)
Gas Oven won't heat but broiler and burners work fine (Oven Repair (including Ranges and Cooktops))
by Melissabrooks 3/4/2018 6:42:44 AM(UTC)
Oven won't heat (Oven Repair (including Ranges and Cooktops))
by mbreihan59 2/5/2018 5:48:30 PM(UTC)
Lower Oven won't heat (Oven Repair (including Ranges and Cooktops))
by akai230 11/7/2016 5:26:07 PM(UTC)
Maytag Gemini oven won't heat (Oven Repair (including Ranges and Cooktops))
by jmatters 11/24/2015 7:23:04 AM(UTC)
GE Profile Convection Oven Won't Heat (Oven Repair (including Ranges and Cooktops))
by igotboost 8/7/2015 10:38:00 AM(UTC)
Ikea Nutid Wall Oven won't heat (Oven Repair (including Ranges and Cooktops))
by Triciav48 6/29/2015 6:36:33 AM(UTC)
Frigidaire oven won't heat (Oven Repair (including Ranges and Cooktops))
by scottrandel 6/28/2015 4:52:44 PM(UTC)
Lower Oven Won't Heat... (Oven Repair (including Ranges and Cooktops))
by FrustratedGeminiOven 3/15/2015 10:45:08 AM(UTC)
by trisha57 4/28/2014 10:23:33 AM(UTC)
Top oven won't heat after self cleaning was done (Oven Repair (including Ranges and Cooktops))
by Dede B 4/6/2014 2:22:53 PM(UTC)
by JLH69 4/5/2014 1:10:19 PM(UTC)
