Turn table and fan turns on when door is opened. Tim Swanson
You have a faulty door switch. Do you have a meter to test with?
GE microwave turntable and fan turn on when door is opened.
The switches are shown as number 1446 in the picture below. Since you have no way to test them, you can replace them both or purchase a test meter. The switches are the same and are available at the link below. As a precaution, there is a potential hazard while servicing, even while unplugged! The large capacitor can hold a charge for a long time after unplugging. If you are not comfortable with this, I would not recommend servicing this microwave yourself. GE WB24X829 Door Sensing Switch - AppliancePartsPros.comAppliance Ninja attached the following image(s):
