2 Pages12>
Glamman
#1 Posted : Wednesday, November 20, 2013 7:11:10 AM(UTC)
Glamman
Hello everyone,
My maytag washer (MVWB700VQ0) has decided to skip the wash & rinse cycles then gives me an "ol" alarm after the machine completes it's spin cycle. All seems to be fine until these cycles. Spins great & no noises, everything moves freely. I've changed out the Control Board (W10187488) & the suspension (W10189077). The timer is good until prior to the wash cycle. It will sit @ (XX min) then jump down to 4 min for the spin cycle. Not sure what else to look @. Thank you for your time!
Appliance Ninja
#2 Posted : Wednesday, November 20, 2013 7:34:28 AM(UTC)
Appliance Ninja
If you lift the inner wash tub, does it lift easily and smoothly?
Glamman
#3 Posted : Wednesday, November 20, 2013 7:40:41 AM(UTC)
Glamman
It does move up and down, but not sure if it's an "easy" move. It's either some kind of tension or a very heavy inner tub.
Appliance Ninja
#4 Posted : Wednesday, November 20, 2013 7:42:43 AM(UTC)
Appliance Ninja
Will the machine fill at the start of a wash cycle?
Glamman
#5 Posted : Wednesday, November 20, 2013 7:47:56 AM(UTC)
Glamman
It fills nicely, drains nicely, & does everything it supposed to until the wash cycle. Either something is telling it not to wash or it just doesn't want to agitate
Appliance Ninja
#6 Posted : Wednesday, November 20, 2013 7:59:55 AM(UTC)
Appliance Ninja
Okay, you likely have an issue with the tub not floating as the water level rises. There may be an article of clothing or something between the two tubs, not allowing the tub to float. Can you remove the inner tub to inspect?
Glamman
#7 Posted : Wednesday, November 20, 2013 8:04:41 AM(UTC)
Glamman
I will definitely take a look, but will take some time. It may take a day or so. Have to go to work now, but if nothing is stuck what do you think may be wrong with it? Thank you Appliance Ninja, I'll post back soon.
Appliance Ninja
#8 Posted : Wednesday, November 20, 2013 8:11:26 AM(UTC)
Appliance Ninja
I believe that to be your problem, so let me know what you find.
Glamman
#9 Posted : Wednesday, November 20, 2013 8:15:28 AM(UTC)
Glamman
Does the inner tub have to come out? I just popped off the top "cover" and looked in between the 2 tubs and it is completely clear. Could it be something underneath?
Glamman
#10 Posted : Wednesday, November 20, 2013 8:23:14 AM(UTC)
Glamman
The machine is clear in between the tubs and underneath.
No wash or spin cycle (Washer Repair)
by barrymcgowan 4/2/2008 1:53:34 PM(UTC)
2 Pages12>
