Frigidaire - GLER331AS2 Came home today from being gone all weekend and found my laundry closet at about 100+ degrees. Dryer was not running, but found that coils stay on (bright orange) when timer knob is turned to an on cycle (timed or automatic, but no turning drum). I turn the knob to an off position and the coils turn off. Any idea what part to replace to keep the coils off when they are supposed to be off? The dryer is not running, but the coils stay on when timer knob is turned to a cycle.
There are two things that can cause that to happen. The first and most common is the heating coil shorts to the case it is mounted on or another spot that is ground. The second is if the centrifugal switch on the motor fails and the contacts stay welded together. It can be tested to determine which it is by measuring the voltage between the two heater terminals. If you read 240 VAC, the motor is bad. If 120 VAC or something close, the heater coil is shorted. Do you have a meter to test voltage with?
Originally Posted by: Appliance Ninja  There are two things that can cause that to happen. The first and most common is the heating coil shorts to the case it is mounted on or another spot that is ground. The second is if the centrifugal switch on the motor fails and the contacts stay welded together. It can be tested to determine which it is by measuring the voltage between the two heater terminals. If you read 240 VAC, the motor is bad. If 120 VAC or something close, the heater coil is shorted. Do you have a meter to test voltage with? I do have a voltmeter, but I'm not sure which contacts to test. Also, how do I tell if the coils are shorted? Everything I've see is pointing tot he timer. You're saying it's not? Thanks so much for the help. This is definitely an area I have no knowledge in.
No, it is not the timer. Unplug the dryer and release the clips in between the front and top panels and hinge the top panel up. You will see the element terminals in the upper RH corner of the machine, behind the drum. Let me know when you get that far, please.
Originally Posted by: Appliance Ninja  No, it is not the timer. Unplug the dryer and release the clips in between the front and top panels and hinge the top panel up. You will see the element terminals in the upper RH corner of the machine, behind the drum. Let me know when you get that far, please. I see those
Okay, with the dryer unplugged, use your meter to test for continuity from each of those terminals to any metal surface on the dryer. Does the meter display change, indicating continuity?
Originally Posted by: Appliance Ninja  Okay, with the dryer unplugged, use your meter to test for continuity from each of those terminals to any metal surface on the dryer. Does the meter display change, indicating continuity? So... the pic attached shows what I'm seeing. If I touch one of the terminals and an area of the dryer, it does beep. Does that mean it's grounded? anthonysessoms attached the following image(s):
Originally Posted by: Appliance Ninja  So glad you could help with this. I take it this kit includes the thermostats? I have noticed a drop in heating performance recently. Is this the cause of it?
The kit includes the belt, idler, both front and rear bearings, drum seal and instructions. The loss of performance is related to the shorted element, the thermostats are good or bad and don't wear down, they just go bad. Replacing the heater and the maintenance kit should keep you going for many more years!
