2 Pages12>
sbryant73
#1 Posted : 11 years ago
sbryant73
My GE washer GTWN5050M0WS is not spinning out all the water out of clothes, I took the front cover off and watched a cycle and it looks like it is working fine but I am not sure how fast it should be spinning. Since heavy clothes like jeans and towels are still very wet when the spin cycle is over I am assuming it is not spinning fast enough. I noticed the drive pulley has a little play in it but not sure if that is normal. The washer is not very old approximately 3-4 years. Any help would be great.
Scott
Appliance Ninja
#2 Posted : 11 years ago
Appliance Ninja
On top of the motor is a metal cover. Under that cover is a green flashing light. How many flashes between pauses, please? Also, does the water pump out rather quickly?
sbryant73
#3 Posted : 11 years ago
sbryant73
Appliance Ninja
On the right side of my motor under the metal cover I have a red flashing light, I did not see a green one any where. It stayed red during a whole wash cycle. I did notice during the spin cycle the red light flashed fairly regularly but sometimes you would see it flash a couple of times fast then resume a normal flash. It also looked like when it flashed fast that the spin would slow down.
Thanks for the help
Appliance Ninja
#4 Posted : 11 years ago
Appliance Ninja
Thank you! Does the water pump out quickly when the pump is initiated? If you select a spin only cycle and start it, does it come to full spin speed?
sbryant73
#5 Posted : 11 years ago
sbryant73
It looks like it drains fine but I don't think it spins as fast as it should. Also is the red blinking light normal, should it be green?
Appliance Ninja
#6 Posted : 11 years ago
Appliance Ninja
The light color is not important, but the number of flashes is. At rest, how many flashes between pause?
sbryant73
#7 Posted : 11 years ago
sbryant73
Single flash then pause at rest.
Here is a video of it spinning
https://www.youtube.com/watch?v=tnxSoQUszyc
Appliance Ninja
#8 Posted : 11 years ago
Appliance Ninja
Yeah, that is too slow. It was flashing during that video but the camera moved at 5 flashes. Can you spin it again, counting the flashes between pauses again, please.
sbryant73
#9 Posted : 11 years ago
sbryant73
Do you want to know the flashes while it is running or when the washer is not on?
sbryant73
#10 Posted : 11 years ago
sbryant73
Here is a 3 min video of the washer on spin cycle with LED flashing.
https://www.youtube.com/watch?v=c8gwT_fCbxo
2 Pages12>
