kylekyle
#1 Posted : 16 years ago
kylekyle
There is a whole in the hose. I put tape on the hose. I think I am supposed to get a new hose but all the stores are closed right now.
Could this be the cause of why my refrigerator has been warm. If I replace the hose will this fix the whole problem - does not seem likely but just want to check if I need service on my GE refrigerator as it has been warm all week. 50 degrees in refrig 22 in freezer.
I was going to shut the water line but I am not sure which of the knobs in basement is the water line
For now I have buckets out
any help appreciated
woodchuckie
#2 Posted : 16 years ago
woodchuckie
For your cooling problem check to see if the coils behind the back cover in the freezer are ice up. You may have a defrost problem.
See if you have a water cut off behind the fridge where the water comes in or under the sink where most are connected.
kylekyle
#3 Posted : 16 years ago
kylekyle
http://forum.appliancepartspros.../31679-refrigerator.html
Do you think that these 2 problems are related.
I am going to fix the hose when I get home from work.
First I will turn off the water valve and then take out the broken hose, then buy a new one and put it where the broken one is now. Is this correct?
My refrigrerator and freezer have been stuck at 50 and 22 degrees for the past 4 days.
I do have GE coming tommorow but it is out of warranty. Do you think that if I replace the hose that the temperatures will return to normal. If they will it would save me a lot by not having to pay GE for service.
woodchuckie
#4 Posted : 16 years ago
woodchuckie
No, the hose leaking would not affect the cooling.
kylekyle
#5 Posted : 16 years ago
kylekyle
ok thanks for the reply.
kylekyle
#6 Posted : 16 years ago
kylekyle
quote]
can you tell me if this is the correct way to replace the hose
woodchuckie
#7 Posted : 16 years ago
woodchuckie
Yes, I think that will do the trick.
