2 Pages12>
ma-henry
#1 Posted : Thursday, November 14, 2013 8:43:10 AM(UTC)
ma-henry
Washer would not spin. Replaced brake assembly and belt. Spins some, but not as good as it used to. Next step, replace springs?
Appliance Ninja
#2 Posted : Thursday, November 14, 2013 8:47:03 AM(UTC)
Appliance Ninja
Did you adjust the belts when they were replaced? The belt in the front that runs around the pump, if you pinch it right in the center, does the motor move before the belt touches?
ma-henry
#3 Posted : Thursday, November 14, 2013 9:43:00 AM(UTC)
ma-henry
I pulled the motor away from the transmission as far as it would go, then tightened the pump.
Appliance Ninja
#4 Posted : Thursday, November 14, 2013 9:46:19 AM(UTC)
Appliance Ninja
If you pinch that belt in the center, does the belt touch before the motor moves?
Appliance Ninja
#5 Posted : Thursday, November 14, 2013 9:57:42 AM(UTC)
Appliance Ninja
When pinching the belt that is around the motor and pump pulley in the center, the motor should move when there is about a finger's width between the belt. If it does not, the belt is too loose and the pump should be loosened and moved to the right to tighten the belt.
ma-henry
#6 Posted : Thursday, November 14, 2013 10:43:41 AM(UTC)
ma-henry
I will try that. If this is not a fix, what's next?
Appliance Ninja
#7 Posted : Thursday, November 14, 2013 10:52:30 AM(UTC)
Appliance Ninja
If it still does not spin fast, you may have some drag from the brake. Let me know what happens.
ma-henry
#8 Posted : Thursday, November 14, 2013 4:42:35 PM(UTC)
ma-henry
I got the pump set so the motor moves when the pump cable is pinched. The transmission won't move unless I pull the motor away from the center. I would cycle it on and off and the trans would only move when the motor was pulled from center. The brake and bearing above it are new My install.
ma-henry
#9 Posted : Thursday, November 14, 2013 4:48:59 PM(UTC)
ma-henry
I noticed the springs under the motor are both on the same side of the motor shaft. Is that standard install?
Appliance Ninja
#10 Posted : Thursday, November 14, 2013 5:00:03 PM(UTC)
Appliance Ninja
The motor should not have that much effect on the transmission turning in spin if the springs are in place. Even if those springs weaken, it should spin the tub. Is the pump all the way to the right, as far as it will go? Did you replace the large belt or the pump belt?
Guest (7)
Maytag Washer won't spin or complete cycle - FIXED! (Washer Repair)
by jimjokjv 10/1/2021 10:08:04 AM(UTC)
Maytag Washer won't Spin just Hums (Washer Repair)
by bnweth 1/4/2017 8:29:35 PM(UTC)
maytag washer won't spin fast (Washer Repair)
by benp1 12/21/2016 5:14:31 PM(UTC)
Maytag Washer Won't Spin (Washer Repair)
by DJames 9/6/2015 5:36:58 PM(UTC)
Maytag Washer won't spin. (Washer Repair)
by spectre_ 1/19/2015 5:24:12 PM(UTC)
Maytag washer won't spin fast enough (Washer Repair)
by dster 1/6/2014 7:06:08 AM(UTC)
by ProfKenn 11/21/2013 6:18:07 PM(UTC)
Maytag washer won't spin and there is a burning smell (Washer Repair)
by figureguy 4/6/2013 11:59:49 AM(UTC)
Maytag Washer won't spin sometimes! (Washer Repair)
by fixit4meNOW 3/21/2013 11:11:25 AM(UTC)
Maytag washer won't spin (Washer Repair)
by Hupper 10/10/2011 12:48:31 PM(UTC)
by treehugger 8/25/2011 12:44:37 PM(UTC)
by erichmann 4/11/2011 6:06:40 PM(UTC)
by randowhite 3/31/2011 11:45:17 AM(UTC)
Maytag Washer Won't Spin or Agitate (Washer Repair)
by scott805 11/16/2010 12:09:40 PM(UTC)
Maytag Washer won't spin (Washer Repair)
by starkdr1 2/27/2010 10:05:08 AM(UTC)
2 Pages12>
