Robin Morgan
#1 Posted : 11 years ago
Robin Morgan
all four burners work but do not get red hot
#2 Posted : 11 years ago
Here are your parts, includes a wiring diagram
Parts for Frigidaire FEC30C4ACD Cooktop - AppliancePartsPros.com
Check the power to/at the unit.
L1 to L2 voltage should be 240 volts.
If OK then you will have to do a live test to see if the 240 is still good when an element is on.
[COLOR="Red"]Be very careful as 240 volts is lethal.[/COLOR]
If you do not have electrical experience then I would get in a pro.
Cook top down draft vent (Oven Repair (including Ranges and Cooktops))
by Guest 2 years ago
Jenn-Air Cook Top Gas Range JGC1526ADS15 (Oven Repair (including Ranges and Cooktops))
by patelvi 3 years ago
kitchenAid Gas Cook top shuts off (Oven Repair (including Ranges and Cooktops))
by kkaiser343 7 years ago
Jenn air gas cook top (Oven Repair (including Ranges and Cooktops))
by Mcalee45@gmail.com 8 years ago
Control Panel not working/oven not working/cook top ok (Oven Repair (including Ranges and Cooktops))
by KarenWallace33458 8 years ago
GE Profile gas, cook top glass #940 (Oven Repair (including Ranges and Cooktops))
by edbabcocko1@gmail.com 9 years ago
GE Cook Top / Sparking from under the knob (Oven Repair (including Ranges and Cooktops))
by nj1971 10 years ago
Jenn Air Cook top Low heat (Oven Repair (including Ranges and Cooktops))
by Curban 10 years ago
Cook top works, but neither bake or broil work and both elements are good (Oven Repair (including Ranges and Cooktops))
by Gene Blake 11 years ago
KitchenAid Electric Range Cook Top no power (Oven Repair (including Ranges and Cooktops))
by coachpelkey 11 years ago
replace cook top (Oven Repair (including Ranges and Cooktops))
by brighten 11 years ago
GE cook top (Oven Repair (including Ranges and Cooktops))
by SKITEXAS 12 years ago
Cook top removal (Oven Repair (including Ranges and Cooktops))
by nickh 12 years ago
Removing Cook Top (Oven Repair (including Ranges and Cooktops))
by Dale Paul 12 years ago
glass cook top replacement (Oven Repair (including Ranges and Cooktops))
by KRAK 12 years ago
