jbain7005
#1 Posted : Wednesday, October 16, 2013 3:44:10 AM(UTC)
jbain7005
I replaced the double heater defrost timer and defrost thermostat in my ge profile tph21pbsbww,it is not fully defrosting.The lower part of the evap coils builds up ice and then cooling stops in the refrigerator section. Is it possible that the heaters can be installed upside down. I noticed the bottom heater does not emit the same amount of heat/light as the top heater.I also noticed that the top heater has more coils per inch in the glass case than the bottom one should that be reversed?
#2 Posted : Wednesday, October 16, 2013 5:51:20 AM(UTC)
Defrost the coils and temporarily short the defrost thermostat. Place in defrost and check the heater coils, if not cherry red, you have a bad/burnt wire someplace.
MayTag defrost issues ????? (Refrigerator & Freezer Repair)
by HHM1435 10/16/2017 1:03:48 PM(UTC)
GE Defrost Issues (Refrigerator & Freezer Repair)
by WVU 9/23/2014 7:40:11 AM(UTC)
Freezer Defrost Issues (Refrigerator & Freezer Repair)
by smuth10 5/9/2013 5:10:31 AM(UTC)
Defrost issues (Refrigerator & Freezer Repair)
by zeke7237 9/23/2011 3:29:06 AM(UTC)
Freezer with defrost issues - dripping water inside. (Refrigerator & Freezer Repair)
by mbockus 8/22/2011 7:43:05 PM(UTC)
by Dennis3816 5/20/2011 10:33:38 AM(UTC)
by wzard841 5/14/2011 4:13:39 PM(UTC)
by stem300 1/18/2011 1:39:02 PM(UTC)
troubleshooting defrost issues (Refrigerator & Freezer Repair)
by iccheap 7/2/2010 11:43:11 AM(UTC)
by wzard841 6/14/2010 6:03:18 AM(UTC)
GE Refrigerator Defrost Issues (Refrigerator & Freezer Repair)
by bhavinjo 5/3/2010 6:01:34 PM(UTC)
Defrost issues with electronoc control (Refrigerator & Freezer Repair)
by dw85075 3/31/2010 6:06:54 PM(UTC)
more defrost issues (Refrigerator & Freezer Repair)
by davidp 1/14/2010 6:54:47 PM(UTC)
GE side by side defrost issues, I looked (Refrigerator & Freezer Repair)
by Hankster 2/3/2008 5:36:29 AM(UTC)
