Beowulf
#1 Posted : Friday, October 4, 2013 4:55:49 AM(UTC)
Beowulf
Can anyone tell me the location of the defrost timer for the Magic Chef RB193AV?
#2 Posted : Friday, October 4, 2013 8:29:18 AM(UTC)
Parts for Magic Chef RB193AV Refrigerator - AppliancePartsPros.com
The timer is item 22 in section 09, so it looks like it is under the unit.
Cannot say if it is behind the kick plat or at the rear of the unit behind the rear cover.
You may not actually be able to see it. It depends how they mounted it but there is usually a hole that will let you turn the timer cam.
Beowulf
#3 Posted : Friday, October 4, 2013 10:53:02 AM(UTC)
Beowulf
Thanks denman...I looked underneath from the front and could see nothing that looks like a defrost timer, or any hole for adjustment. When I checked from behind, I could not see it either...I will look again. Perhaps it is attached to the compressor.
#4 Posted : Saturday, October 5, 2013 4:16:44 AM(UTC)
It should not be attached to the compressor but may be close to it.
Defrost timers are normally either in the machine/compressor compartment or in the control console in the fresh food section.
Since the parts breakdowns show it in the machine compartment I think that is where it is but am not sure.
Beowulf
#5 Posted : Monday, October 7, 2013 6:46:23 AM(UTC)
Beowulf
Thanks denman: found it! It was screwed onto the inside of the frame at the back left close to the wiring harness. The opposite side to the indication on the parts diagram.
Guest (4)
Whirlpool upright freezer defrost timer location (Refrigerator & Freezer Repair)
by georgerose 9/6/2014 6:49:53 AM(UTC)
Whirlpool defrost timer location? (Refrigerator & Freezer Repair)
by TomD62 4/20/2014 7:00:06 PM(UTC)
Kenmore Defrost Timer Location (Refrigerator & Freezer Repair)
by frigadare 10/2/2012 9:58:24 AM(UTC)
Admiral Defrost Timer Location (Refrigerator & Freezer Repair)
by alshadow 10/3/2011 6:34:56 PM(UTC)
by aaron bremiller 6/17/2011 8:33:35 AM(UTC)
Defrost timer location (Refrigerator & Freezer Repair)
by WayneW 7/12/2010 12:13:32 PM(UTC)
Defrost Timer Location & Part Number (Refrigerator & Freezer Repair)
by ptisteve 6/29/2010 11:38:25 PM(UTC)
Defrost Timer location (Refrigerator & Freezer Repair)
by manhhung29 5/3/2010 4:39:21 PM(UTC)
by bobo123 2/14/2010 2:11:50 PM(UTC)
defrost timer location for older Kenmore (Refrigerator & Freezer Repair)
by jeff92rs 7/29/2009 9:26:35 AM(UTC)
Not defrosting - need defrost timer location, icemaker remove/reinstall info (Refrigerator & Freezer Repair)
by LeeHamilton 7/20/2009 2:05:53 PM(UTC)
by Orlando54 7/9/2009 6:38:50 AM(UTC)
Defrost Timer locations (Refrigerator & Freezer Repair)
by EamonAidanAlexa 5/26/2009 8:28:56 AM(UTC)
by RyanCasey 1/25/2009 7:39:59 PM(UTC)
Frigidaire defrost timer location? (Refrigerator & Freezer Repair)
by jlanza 1/17/2009 1:26:14 PM(UTC)
