65fordf150
#1 Posted : Tuesday, April 28, 2009 4:51:01 PM(UTC)
65fordf150
when turned on the water wont come on it just starts to agitate. the water is on it worked fine on the last load. if i set it to spin it will spin.
#2 Posted : Wednesday, April 29, 2009 2:55:39 AM(UTC)
Cannot find any info using the given Model Number, please check it.
Sounds like the machine thinks it is full of water already.
Unplug the unit
Open up the control console, with a little luck you will find your wiring diagram in there.
Check the water level switch with a meter.
The Normally Closed switch should be closed (O ohms) and the Normally Open side open (infinite ohms)
If not, remove the tube from the water level switch assembly.
If it is now OK your tubing is probably clogged up, blow into it to clear the clog.
If it does not switch over then the level switch is toast.
Here is a good site with additional info
http://www.applianceaid.com/washers.html
KitchenAid Dishwasher no water (Dishwasher Repair)
by tjlester 9/25/2020 10:51:39 AM(UTC)
MHWE550WJ01 Maytag Front Load Washer No Water (Washer Repair)
by alligatorous 7/27/2020 11:07:06 PM(UTC)
Whirlpool Washer No Water (Washer Repair)
by bgreer2525 7/19/2020 5:55:02 AM(UTC)
Maytag Dishwasher no water coming in (Dishwasher Repair)
by my2monkeys 8/18/2012 3:55:02 PM(UTC)
Whirlpool Top Load Washer no water (Washer Repair)
by al-lawn 7/27/2012 2:02:32 PM(UTC)
by lyowasher 6/1/2012 3:37:57 PM(UTC)
Bosch Dishwasher no water fault (Dishwasher Repair)
by tallerpaul007 2/18/2012 2:50:13 AM(UTC)
dishwasher no water to the top rack (Dishwasher Repair)
by itskieron 8/3/2011 10:41:49 AM(UTC)
Fisher Paykel Dishwasher No water/Power cord (Dishwasher Repair)
by lizzygrace 3/26/2011 6:23:32 PM(UTC)
Dishwasher No Water to Top (Dishwasher Repair)
by Joe Fraga 11/8/2010 5:11:18 PM(UTC)
Whirlpool dishwasher no water heating or drying (Dishwasher Repair)
by coliecam 10/26/2010 6:01:01 AM(UTC)
Dishwasher no water to bottom arm (Dishwasher Repair)
by tyson8000 5/27/2009 4:40:43 AM(UTC)
washer no water (Washer Repair)
by 65fordf150 4/28/2009 5:26:33 PM(UTC)
maytag washer/dyer combo washer no water (Washer Repair)
by lindavanzandt 11/30/2008 7:35:52 AM(UTC)
KitchenAid Dishwasher no water from arms (Dishwasher Repair)
by steven d 10/24/2008 9:53:04 AM(UTC)
