maxy212
#1 Posted : Wednesday, September 25, 2013 5:24:00 PM(UTC)
maxy212
COLD/COLD AND HOT/HOT FILL THE TUB, BUT WHEN PUT ON WARM/WARM AND COLD/COLD WILL NOT FILL. AND RINSE WILL NOT FILL AT ALL.:confused:
fairbank56
#2 Posted : Wednesday, September 25, 2013 6:08:49 PM(UTC)
fairbank56
Groups: Expert
Your statements are contradictory. There is no HOT/HOT or WARM/WARM. Rinse is cold only. You say COLD/COLD fills and then say COLD/COLD does not fill. There are two COLD/COLD settings on this washer, one ATC and one non-ATC. Check your cold water supply and make sure screens in fill hose and/or water inlet valve is/are clear of debris.
Eric
maxy212
#3 Posted : Wednesday, September 25, 2013 7:02:19 PM(UTC)
maxy212
Eric
On wash the setting for water temperature say warm/warm, hot/hot, cold/cold/ warm/warm these are for wash and rinse. the water fills on warm and hot but won't fill on warm or cold settings and water will not fill on rinse at all. These are the setting showing on the panel of my washing machine, don't know what you are saying. BUT THESE ARE WHAT IS SHOWING ON MY WASHING MACHINE.
fairbank56
#4 Posted : Wednesday, September 25, 2013 7:37:44 PM(UTC)
fairbank56
Groups: Expert
Then I'd like to see a photo of your control panel because I have the tech sheet for your washer and a photo of a control panel from that model number washer and both show cold/cold, cool/cold, warm/cold and hot/cold temperature settings. Maybe you have an international version of this washer but I would think the model number would be different. Are you in the U.S.? This is an 09 model and there aren't any models of that year in the U.S. that use anything other than a cold rinse, due to government regulations. Did you make the check that I suggested?
Eric
maxy212
#5 Posted : Wednesday, September 25, 2013 8:12:26 PM(UTC)
maxy212
Eric
I am saying when put on wash this problem exists. And rinse will not fill at all
fairbank56
#6 Posted : Thursday, September 26, 2013 4:47:19 AM(UTC)
fairbank56
Groups: Expert
If you won't give me any feedback on my questions and suggestions, I can't help you.
Eric
maxy212
#7 Posted : Thursday, September 26, 2013 7:50:49 AM(UTC)
maxy212
Eric
thanks for your help, I guess I didn't make myself clear, the different temps are on the wash cycle. and only the hot and cold fill, the other temps don't fill and the rise doesn't fill either. Guess I went into to much detail in my first post.
fairbank56
#8 Posted : Thursday, September 26, 2013 8:18:39 AM(UTC)
fairbank56
Groups: Expert
There's cold, cool, warm and hot on the wash cycle. Only cold on the rinse cycle, unless you have some non-US version of this washer. If your saying hot wash will fill and cold wash will fill but warm and cool will not (no water coming in at all), then I'd say you have a faulty ATC (temp) switch. No cold water at all in any rinse cycle could be the ATC or a faulty timer. I don't have much confidence in your symptoms based on the way you are describing them so I really can't say for sure. Troubleshooting this problem with multimeter and wiring diagram will quickly pinpoint the problem but if you have no experience in that area, you are left with parts swapping to locate the problem. If you buy the parts from APP, you may return them if they don't solve the problem.
Whirlpool W10184148 Atc Switch Mid Level - AppliancePartsPros.com
Whirlpool W10199989 Timer - AppliancePartsPros.com
Eric
maxy212
#9 Posted : Thursday, September 26, 2013 9:13:26 AM(UTC)
maxy212
We were sent a defective switch, thanks we don't need any more responses, we have the problem fixed. Thanks everyone.
maxy212
#10 Posted : Wednesday, October 2, 2013 3:05:54 PM(UTC)
maxy212
Eric
we replace the temp switch and thought that was the problem, it did solve part of it but still won't fill in rinse cycle.
