mani
#1 Posted : Tuesday, April 28, 2009 7:38:36 PM(UTC)
mani
dryer wont heat,check all the themostate and thermel cut off and also thermel fuse.it tumble but it did not heat,i diagnosed the 110 which come from motor is coming but other 110 is missing which come from some where control system,what could be wrong
#2 Posted : Wednesday, April 29, 2009 3:27:43 AM(UTC)
Here is the tech sheet
https://www.servicematters.com/d...0Sheet%20-%203980052.pdf
Check that you have the proper power at the plug.
L1 to Neutral and L2 to Neutral should be 120 volts
Also L1 to L2 should be 240 volts.
It is not uncommon to loose half the line without actually tripping the breaker.
Depending on which side drops out the unit will run but not heat.
Flip the breaker off/on slowly a couple times.
Be careful, 240 volts is lethal.
mani
#3 Posted : Wednesday, April 29, 2009 4:00:18 AM(UTC)
mani
thank u for your response,there is no problem with power ,L1 and L2 already giving me 240
#4 Posted : Wednesday, April 29, 2009 4:13:32 AM(UTC)
Is the heater itself OK?
Looks like the heater relay and the motor relay are the same.
Check this just to be sure.
If they are the same, swap them
Now if it will not start you know the relay is shot.
mani
#5 Posted : Wednesday, April 29, 2009 4:17:39 AM(UTC)
mani
yes i am thinking aswell this could be the heater relay but not a control board which is beside the relay? thank you for your quick response
#6 Posted : Wednesday, April 29, 2009 5:27:38 AM(UTC)
Could be the control board but you want to eliminate everything else before coming to that conclusion as it is the most expensive part.
Whirlpool built in micro/oven combo unit wont heat after self clean - thermal fuse ok (Oven Repair (including Ranges and Cooktops))
by parangil 2/7/2015 11:14:22 AM(UTC)
