kathryn13
#1 Posted : 11 years ago
kathryn13
:confused:Washer will fill and spin but will not agitate.
fairbank56
#2 Posted : 11 years ago
fairbank56
Groups: Expert
We need the model number of the washer.
Eric
kathryn13
#3 Posted : 11 years ago
kathryn13
Wwsr3090t6ww
fairbank56
#4 Posted : 11 years ago
fairbank56
Groups: Expert
Take the front panel off the machine by inserting a putty knife into the top groove in line with the lid opening on each side to release the clips, tilt panel outward and lift from machine. Does the motor run when it should be agitating? Does it hum? Is it totally quiet?
Eric
kathryn13
#5 Posted : 11 years ago
kathryn13
Motor does run when it should be agitating.
fairbank56
#6 Posted : 11 years ago
fairbank56
Groups: Expert
And belt and main drive pulley are turning?
kathryn13
#7 Posted : 11 years ago
kathryn13
Still trying to get front cover off - being stubborn and I am not a fixer.
kathryn13
#8 Posted : 11 years ago
kathryn13
Small tubing connected to drum on left but not on right seems to be disconnect not sure if one piece or broke.
kathryn13
#9 Posted : 11 years ago
kathryn13
Found problem 3 parts holding the drum have broken. TY
kathryn13
#10 Posted : 11 years ago
kathryn13
Ty found problem
GE washer grinding noise (Washer Repair)
by gefixin 10 months ago
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel about a year ago
GE washer GTW750CPL0DG (Washer Repair)
by Guest about a year ago
GE Washer with bad transmission? (Washer Repair)
by fljlee3 about a year ago
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 about a year ago
GE washer drain problem (Washer Repair)
by gurka75 about a year ago
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 2 years ago
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 2 years ago
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 2 years ago
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2 years ago
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2 years ago
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2 years ago
GE washer wbse4220aoww (Washer Repair)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 2 years ago
