kathryn13
#1 Posted : Friday, September 20, 2013 12:48:12 PM(UTC)
kathryn13
:confused:Washer will fill and spin but will not agitate.
fairbank56
#2 Posted: : Friday, September 20, 2013 12:56:16 PM(UTC)
fairbank56
Groups: Expert
We need the model number of the washer.
Eric
kathryn13
#3 Posted : Friday, September 20, 2013 1:05:21 PM(UTC)
kathryn13
Wwsr3090t6ww
fairbank56
#4 Posted : Friday, September 20, 2013 1:12:29 PM(UTC)
fairbank56
Groups: Expert
Take the front panel off the machine by inserting a putty knife into the top groove in line with the lid opening on each side to release the clips, tilt panel outward and lift from machine. Does the motor run when it should be agitating? Does it hum? Is it totally quiet?
Eric
kathryn13
#5 Posted : Friday, September 20, 2013 1:17:06 PM(UTC)
kathryn13
Motor does run when it should be agitating.
fairbank56
#6 Posted : Friday, September 20, 2013 1:23:18 PM(UTC)
fairbank56
Groups: Expert
And belt and main drive pulley are turning?
kathryn13
#7 Posted : Friday, September 20, 2013 1:25:16 PM(UTC)
kathryn13
Still trying to get front cover off - being stubborn and I am not a fixer.
kathryn13
#8 Posted : Friday, September 20, 2013 1:43:13 PM(UTC)
kathryn13
Small tubing connected to drum on left but not on right seems to be disconnect not sure if one piece or broke.
kathryn13
#9 Posted : Friday, September 20, 2013 2:27:02 PM(UTC)
kathryn13
Found problem 3 parts holding the drum have broken. TY
kathryn13
#10 Posted : Friday, September 20, 2013 2:29:42 PM(UTC)
kathryn13
Ty found problem
GE washer grinding noise (Washer Repair)
by gefixin 5/20/2024 2:01:39 PM(UTC)
GE Washer Topload model I have a GE top load washer GTW750CPL0DG. It fills and it is running but whe (Washer Repair)
by MimiReel 1/28/2024 12:03:27 PM(UTC)
GE washer GTW750CPL0DG (Washer Repair)
by Guest 1/28/2024 11:49:12 AM(UTC)
GE Washer with bad transmission? (Washer Repair)
by fljlee3 1/16/2024 10:50:07 AM(UTC)
GE washer and dryer lost face clothes (Washer Repair)
by chris24681012 12/19/2023 5:44:47 AM(UTC)
GE washer drain problem (Washer Repair)
by gurka75 11/16/2023 10:07:53 AM(UTC)
GE washer model GTWN4250D0WS fill water but will not agitate or spin during wash cycle (Washer Repair)
by Dweynand 8/29/2023 7:01:15 PM(UTC)
GE Washer model GFAN1000L2WW. Stucked during the washing process with no agitation. (Washer Repair)
by Guest 8/24/2023 4:22:18 PM(UTC)
GE Washer GLWN5550D0WW trying to test if the shifter disengage from the wash basket (Washer Repair)
by steveh1776 3/27/2023 6:00:43 AM(UTC)
GE washer will spin but will not agitate on the wash cycle (Washer Repair)
by Jodibrewer2002@yahoo.com 2/14/2023 10:39:58 AM(UTC)
GE WASHER MAKES GOD AWFUL SOUND AFTER FILLING WITH WATER (Washer Repair)
by Guest 2/12/2023 5:04:03 PM(UTC)
GE Washer GTW335ASN1WW (Washer Repair)
by jmulc82189 2/8/2023 10:36:12 AM(UTC)
GE Washer Ending Cycle after abt 3-5 mins (Washer Repair)
by FelixSS 2/6/2023 5:37:03 PM(UTC)
GE washer wbse4220aoww (Washer Repair)
by Guest 9/21/2022 2:04:51 PM(UTC)
GE washer- washes clothes, spins, drains then fills w water again (Washer Repair)
by Skep19 9/19/2022 9:36:54 AM(UTC)
