JeffBrannon
#1 Posted : Monday, September 16, 2013 9:21:34 AM(UTC)
JeffBrannon
My Roper dryer won't start. My wife had just finished drying a load and put another load in to dry and it wouldn't start. When you turn the timer to a setting you do hear some clicks but it won't start up.
I turned the timer on around, when it got to the fluff setting it did come on. When I took my hand off of the timer it kinda clicked back a notch maybe and stopped. It would repeat this action but only on fluff setting.
I haven't tested anything yet.
What should I check first?
Thanks!
#2 Posted : Tuesday, September 17, 2013 3:03:09 AM(UTC)
Parts for Roper RES6745PQ0 Dryer - AppliancePartsPros.com
See the attachment for the wiring diagram.
Since the unit will start in air fluff the start switch, motor and thermal fuse are OK.
Sounds like a timer problem.
Set the timer to a problem area.
Unplug the unit.
Check BK to BU on the timer, should be 0 ohms.
Check T to W, should be 0 ohms.
It is a good idea to disconnect one side of the contact set you are checking. This ensures that you do not read an alternate/parallel circuit path.
Also use the most sensitive meter scale and short the meter leads together before starting. This will tell you if there is a zero offset in the meter.
File Attachment(s):
RES6745.pdf (156kb) downloaded 4 time(s).
Roper Dryer won't start (Dryer Repair)
by timothy3784 8/8/2012 6:51:36 AM(UTC)
by iy@nts-online.net 1/27/2012 6:06:52 PM(UTC)
Roper Dryer Won't Start - Replaced Thermal Fuse (Dryer Repair)
by ladodgersfan88 7/9/2010 10:56:19 AM(UTC)
Roper Dryer Won't Start (Dryer Repair)
by jfemal 3/15/2009 10:00:07 AM(UTC)
Roper Dryer won't start... (Dryer Repair)
by deanna08 12/18/2008 1:57:56 PM(UTC)
