seanjdawson
#1 Posted : Friday, September 6, 2013 9:34:59 AM(UTC)
seanjdawson
Soap is not completely rinsing out of soap dish. Arm under top rack is not spinning. I have read a few posts. Water level seems fine. Just touching the bottom of heating element. I cleaned out all the inside parts less than a month ago. I'm tempted to do it over again but I'm wondering if something else could be wrong. The spray arm moves fine by hand and there seems to be plenty of water coming out of it. It just won't spin.
Thanks in advance for feedback.
Sean
seanjdawson
#2 Posted : Friday, September 6, 2013 2:11:10 PM(UTC)
seanjdawson
cleaned out dishwasher again anyway. It was relatively clean until I got to the food chopper which was completely covered in food. Seems like it should have lasted longer than 3 weeks. I cleaned it again thoroughly and am now doing a rinse cycle with vinegar. When it's is done I'll put it back together and see if it cleans dishes.
#3 Posted : Saturday, September 7, 2013 6:59:11 AM(UTC)
Check the holes at the ends of the spray arms.
They are at an angle and are what cause the arms to spin.
Let it run and then open the door and check them.
Sometimes if it is a large chunk it will block the hole but fall back into the arm when the arm is dry.
wetEtehypemem
#4 Posted : Wednesday, September 11, 2013 8:44:35 AM(UTC)
wetEtehypemem
Hi! I've recently found amazing haarausfall stoppen
wetEtehypemem
#5 Posted : Wednesday, September 11, 2013 9:10:01 AM(UTC)
wetEtehypemem
Hi everyone! I've recently discovered brilliant haarausfall männer
seanjdawson
#6 Posted : Wednesday, September 11, 2013 2:36:10 PM(UTC)
seanjdawson
Thank you. It is working fine. It was the food chopper that was clogged. I had just cleaned out the entire machine about 3 weeks ago. I didn't find any debris anywhere else except the food chopper. It may need to be replaced. If it plugs up again sooner rather than later I'll try replacing it. Thanks for your post though.
fgip2468uf1a lower spray arm not spinning (Dishwasher Repair)
by JohnET 4/6/2024 10:27:47 AM(UTC)
Frigidaire lower spray arm not spinning (Dishwasher Repair)
by Alx137 6/6/2022 6:44:30 PM(UTC)
Center spray arm not spinning (Dishwasher Repair)
by Moleski 1/26/2016 9:28:31 AM(UTC)
Spray arm not spinning (Dishwasher Repair)
by Mersky 5/7/2012 8:45:16 AM(UTC)
Maytag Dishwasher - lower spray arm not spinning (Dishwasher Repair)
by MarkOpti 8/1/2011 6:55:17 PM(UTC)
by artrader 5/4/2011 8:10:33 PM(UTC)
Whirlpool Dishwasher spray arm not spinning (Dishwasher Repair)
by dgraigm 8/21/2010 8:51:56 AM(UTC)
