warrenl2
#1 Posted : Sunday, August 25, 2013 11:19:09 AM(UTC)
warrenl2
Extra rinse does not work
fairbank56
#2 Posted : Sunday, August 25, 2013 11:57:54 AM(UTC)
fairbank56
Groups: Expert
Open the control panel and check continuity of the extra rinse switch. This is the exact same switch as your fabric softener switch if you just want to try swapping them.
Whirlpool W10168257 Cycle Switch - AppliancePartsPros.com
If the switch checks out ok, the timer is faulty.
Whirlpool W10177827 Timer - AppliancePartsPros.com
Eric
warrenl2
#3 Posted : Sunday, August 25, 2013 3:26:30 PM(UTC)
warrenl2
OK, I suspected that. Now, how do I get to the control panel. Other Sears i have had were straight forward
warrenl2
#4 Posted : Sunday, August 25, 2013 3:28:25 PM(UTC)
warrenl2
OK I suspected that. Now how do I get to the control panel?
warrenl2
#5 Posted : Sunday, August 25, 2013 4:11:51 PM(UTC)
warrenl2
Eric, Thank you! You will not believe what a dummy I am. Either the extra rinse never worked or the contact block vibrated off, but the switch was not connected. Got it fixed.
Maytag mav8260aww Quiet Plus II extra rinse issue (Washer Repair)
by Kaervak 1/19/2021 6:35:07 PM(UTC)
Extra Rinse Switch (Washer Repair)
by ronaldo47 1/8/2014 9:34:41 AM(UTC)
Whirlpool - Knob advances through regular wash cycle to run extra rinse cycle (Washer Repair)
by Lee Lee 5/23/2013 6:48:32 PM(UTC)
Whirlpool Washer only operates in Extra Rinse (Washer Repair)
by jegfla1 2/19/2013 1:31:56 PM(UTC)
Maytag Stops at Extra Rinse (Washer Repair)
by chasepawpaw 7/26/2012 8:33:02 AM(UTC)
washer continues to fill when extra rinse buton is depressed (Washer Repair)
by dpinka 1/22/2011 2:37:25 PM(UTC)
