warrenl2
#1 Posted : 12 years ago
warrenl2
Extra rinse does not work
fairbank56
#2 Posted : 12 years ago
fairbank56
Groups: Expert
Open the control panel and check continuity of the extra rinse switch. This is the exact same switch as your fabric softener switch if you just want to try swapping them.
Whirlpool W10168257 Cycle Switch - AppliancePartsPros.com
If the switch checks out ok, the timer is faulty.
Whirlpool W10177827 Timer - AppliancePartsPros.com
Eric
warrenl2
#3 Posted : 12 years ago
warrenl2
OK, I suspected that. Now, how do I get to the control panel. Other Sears i have had were straight forward
warrenl2
#4 Posted : 12 years ago
warrenl2
OK I suspected that. Now how do I get to the control panel?
warrenl2
#5 Posted : 12 years ago
warrenl2
Eric, Thank you! You will not believe what a dummy I am. Either the extra rinse never worked or the contact block vibrated off, but the switch was not connected. Got it fixed.
Maytag mav8260aww Quiet Plus II extra rinse issue (Washer Repair)
by Kaervak 4 years ago
Extra Rinse Switch (Washer Repair)
by ronaldo47 11 years ago
Whirlpool - Knob advances through regular wash cycle to run extra rinse cycle (Washer Repair)
by Lee Lee 12 years ago
Whirlpool Washer only operates in Extra Rinse (Washer Repair)
by jegfla1 12 years ago
Maytag Stops at Extra Rinse (Washer Repair)
by chasepawpaw 13 years ago
washer continues to fill when extra rinse buton is depressed (Washer Repair)
by dpinka 14 years ago
