erniehillsman
#1 Posted : Monday, April 27, 2009 6:04:31 AM(UTC)
erniehillsman
I made a mistake when replacing the motor control board. The little plug on top is also able to be pluged in next to the proper spot which I did. Now it wont spin or aggitate. The self test says to replace the speed control board. So I guess my mistake cost me that board. The problem is it is not listed on the parts list to order. So where is it and what is it called so I can order it. Thanks
Drags1998
#2 Posted : Monday, April 27, 2009 12:54:37 PM(UTC)
Drags1998
AP3891780 motor comtrol board. There are 2 boards in that unit, A MAIN control board and The MOTOR control board.:)
erniehillsman
#3 Posted : Monday, April 27, 2009 1:59:16 PM(UTC)
erniehillsman
Thanks, just want you to know that in the beginning it would aggitate and not spin which it had a code of e47 that called for a control board replacement. When I put the plug in the wrong place it would not aggitate or spin. so I tried the old one and it would not aggitate or spin either. And now the code is e5e calling for a speed control board. Do you still think it is the control board since both of them do not aggitate or spin. I think you so much for your help.
Drags1998
#4 Posted : Monday, April 27, 2009 2:23:53 PM(UTC)
Drags1998
I had 1 of these last month that the code was E43 (control board) I replaced the MAIN control board, STILL NO SPIN!!!!! called tech line, They said "Replace the door lock Mech. I did and the machine runs PERFECT!!!!! DON"T ALWAYS believe the Tech sheet!!!!:)
erniehillsman
#5 Posted : Monday, April 27, 2009 2:28:18 PM(UTC)
erniehillsman
Thank you for your help
How to test door latch and speed control board (Washer Repair)
by Bucky6563 5/29/2012 12:16:17 PM(UTC)
Testing speed control board (Washer Repair)
by chrischr64 7/18/2011 6:18:08 AM(UTC)
Speed control board (Washer Repair)
by den1 12/20/2007 7:35:53 AM(UTC)
