jrcr.inc
#1 Posted : Saturday, August 10, 2013 6:14:22 AM(UTC)
jrcr.inc
The dryer makes a noise when it starts and it leaves marks on the clothes. The tub moves front to back. Could this be a bearing issue? Something else?
HumboldtRepairMan
#2 Posted : Saturday, August 10, 2013 7:29:15 AM(UTC)
HumboldtRepairMan
It could be a bearing issue typically bearings will make a screech or squeel most the time when the plastic is worn and is metal to metal but it could be your plastic piece worn strange, also could be a bearing screw or 2 that came out and it's spinning on 1 screw rather then 3 or more..............Could be a glide worn on the front plastic pieces.........could be a bent drum.....could be a felt issue.....could just be misaligned off the front panel.....these are things you'll have to figure out yourself when breaking it down and dismantling it........check out sears parts website for schematics on your machine and breakdown procedure.......good luck
GE DPGT650EHWW Dryer issues... (Dryer Repair)
by Guest 8/27/2022 3:30:50 PM(UTC)
Dryer issues (Dryer Repair)
by David Borges 7/20/2017 1:14:48 PM(UTC)
whirlpool dryer issues (Dryer Repair)
by sasko0711 2/28/2014 6:18:05 PM(UTC)
Whirlpool Electric Dryer Issues (Dryer Repair)
by samedpaul 1/16/2014 9:02:04 AM(UTC)
maytag neptune dryer issues (Dryer Repair)
by blueovalfever 10/14/2013 6:25:43 AM(UTC)
Maytag Dryer issues (Dryer Repair)
by jpstuhr 5/27/2011 7:52:45 AM(UTC)
by joanneggay 2/18/2011 2:44:30 PM(UTC)
by JeffCPA 11/30/2010 3:51:39 PM(UTC)
Kenmore Electric Dryer Issues - Motor Capacitor? (Dryer Repair)
by wklages7 5/26/2010 8:50:16 AM(UTC)
Electric Whirlpool Dryer Issues (Dryer Repair)
by Fusion 2/14/2010 4:58:14 PM(UTC)
by SteveDB 1/30/2010 2:18:09 PM(UTC)
Kenmore dryer issues (Dryer Repair)
by ctaylor1127 6/3/2009 6:00:43 AM(UTC)
by gman357 11/16/2008 2:40:13 PM(UTC)
by zal 11/3/2008 11:19:37 AM(UTC)
Gas dryer issues, no flame!!! (Dryer Repair)
by xj1978 9/21/2008 5:47:48 AM(UTC)
