badabing
#1 Posted : Monday, April 28, 2008 5:32:22 PM(UTC)
badabing
One of the large burners has stopped working on my glass top stove. What should I check first?
misterfixall
#2 Posted : Monday, April 28, 2008 5:51:51 PM(UTC)
misterfixall
super capacity 465 is not a model number, pull out oven drawer ,where drawer meets frame there is a sticker on frame that says model number+ serial number
car62
#3 Posted : Sunday, April 26, 2009 1:40:50 PM(UTC)
car62
Was there an answer to this post? I have the same problem on a 2002 Amana glass cooktop stove.
donburrer
#4 Posted : Monday, April 27, 2009 6:16:35 AM(UTC)
donburrer
I have an Amana glass stove top (Model AK2H30HR)which just has a burner that no longer works. I am about to order a replacement "7" ribbon element" and since I will have it apart I am also going to order a new "limiter" for the burner. Are chances good that that will fix the problem? Thanks
#5 Posted : Monday, April 27, 2009 6:02:03 PM(UTC)
badabing and car62,
If you are looking for professional advice then you have to post the complete model number of the product and most possible description on the problem.
#6 Posted : Monday, April 27, 2009 6:10:40 PM(UTC)
You do not have to order a new limiter because it comes with a new element. I would check for continuity the infinite switch for this burner.
Here are the breakdown diagrams and Replacement parts for AMANA AK2H30HR | AppliancePartsPros.com
donburrer
#7 Posted : Tuesday, April 28, 2009 4:07:51 AM(UTC)
donburrer
Thanks, Gene. I can check the continuity of the switch. However, the "burner on" indicator light does go on. Is it a two or a single pole switch? Don
#8 Posted : Wednesday, April 29, 2009 2:00:57 PM(UTC)
It is a two pole switch.
Guest (4)
