SamRener
#1 Posted : Sunday, July 28, 2013 3:00:51 PM(UTC)
SamRener
Dryer starts the immediately stops. Tried the diag test select/cancel 6 seconds buzzer sounds once rotate knob counter clockwise 5 turns (second from bottom) select/option 2 sec buzzer sounds 3 times all leds flashing turn clockwise 1 to test motor / heat **** at this point the dryer acts like it wants to start and stops immediately. Same as it does when we try to use it. Then exits test mode. I cant test anything else in this mode as i can not get past the first turn. Tried field test mode (from another post on this forum) 1. Press and hold the Select and Cancel buttons simultaneously for 6 seconds to reset control. The buzzer will sound 1 time and “rES” will be shown briefly in the display. 2. Immediately after, rotate cycle selector knob 2 turns counter-clockwise to the third position from the top, and then press and hold the Select and Cancel buttons simultaneously for 6 seconds. The control will enter Field Test Mode, the buzzer will sound 3 times, and the digital display will alternate between “Fld” and the firmware revision number (ex. “r03”). 3. Rotate the cycle selector knob 2 turns counterclockwise. The error code will appear in the digit display. got Fld / r08 then the error code E05 any thoughts
HumboldtRepairMan
#2 Posted : Sunday, July 28, 2013 3:14:47 PM(UTC)
HumboldtRepairMan
Check under the touchpad for the tech sheet or you can check your manual and look up the code it should guide you to look at the proper circuitry. If i'm not mistaken this is associated with something in the motor circuitry.
lg dryer will not start (Dryer Repair)
by Guest 8/30/2022 11:16:45 AM(UTC)
Maytag dryer will not start (Dryer Repair)
by Kabel69 10/14/2017 3:03:55 PM(UTC)
Dryer will not start (Maytag MEDC300BW) (Dryer Repair)
by Brad S 9/26/2017 9:12:45 AM(UTC)
by vassarrepair 2/2/2017 6:32:18 AM(UTC)
Gas dryer will not start (Dryer Repair)
by needhelp22 1/11/2016 6:45:33 AM(UTC)
Whirlpool Dryer will not start (Dryer Repair)
by 123zorn 12/3/2015 5:01:02 PM(UTC)
estate dryer will not start! (Dryer Repair)
by robmacdaddy 11/23/2015 7:34:08 AM(UTC)
BRAND NEW kenmore dryer will not start!!! (Dryer Repair)
by clarajj 10/19/2015 5:29:21 AM(UTC)
Dryer will not start. No Display. (Dryer Repair)
by gw2015 8/8/2015 7:45:27 AM(UTC)
Neptune dryer will not start-fuses and door switch works (Dryer Repair)
by Maryland1 1/10/2015 12:02:30 PM(UTC)
Whirlpool Ultimate Care II dryer will not start (Dryer Repair)
by jajinnette 12/14/2014 10:09:44 AM(UTC)
Help! Dryer will not start (Dryer Repair)
by Chrisk4099 12/9/2014 3:07:35 PM(UTC)
Whirlpool Duet Dryer will not start (Dryer Repair)
by brbckg 9/7/2014 4:51:22 PM(UTC)
by saaman 8/21/2014 12:46:47 PM(UTC)
Maytag Dryer will not start... (Dryer Repair)
by robert45 8/8/2014 11:46:53 AM(UTC)
