Donald Belanger
#1 Posted : Monday, December 10, 2007 5:39:45 PM(UTC)
Donald Belanger
Just Installed New Belt.had Problem Keeping Belt In Center Of Pully.will This Adjust Itself,or Do I Still Have Other Problems?don't Know If Belt Is Properly Insalled. Thanks,donald
TechnicianBrian
#2 Posted : Monday, December 10, 2007 5:55:52 PM(UTC)
TechnicianBrian
The belt will self adjust on front load washers. If it hangs over the front or the rear of the large pulley, just move it in the opposite direction on the small pulley to correct it unit it is centered on the large pulley.
TechnicianBrian
Donald Belanger
#3 Posted : Tuesday, December 11, 2007 2:26:30 PM(UTC)
Donald Belanger
Belt Stayed On About 3 Loads Of Wash,then Sliped Of,also Noticed Rubbing Marks Inside.think I Have Bad Bearing.
TechnicianBrian
#4 Posted : Tuesday, December 11, 2007 2:46:56 PM(UTC)
TechnicianBrian
You want to take hold of the basket assembly and try moving it within the tub to check for bearing wear. It should not move top to bottom,side to side, or front to rear at all. If you can move it up and down, or side to side, the bearing is bad and you will need to replace the rear tub assembly (the bearing comes with it) and possibly the basket spider depending on how worn it is.
TechnicianBrian
Donald Belanger
#5 Posted : Tuesday, December 11, 2007 5:32:21 PM(UTC)
Donald Belanger
Thank's Brian,maybe Time To Replace. Donald
Guest (4)
Front Loader washing machine will not fill. E5E error code. (Washer Repair)
by jjuly 7/3/2024 12:25:33 PM(UTC)
GE Top Loader Washing Machine Leaking from bottom (Washer Repair)
by Guest 6/13/2024 9:46:30 AM(UTC)
whirlpool washing machine model wtw57esvw0 (Washer Repair)
by Guest 5/7/2024 7:57:17 AM(UTC)
Help! Washing machine on repeat rinse cycle (Washer Repair)
by cali.poppy 4/29/2024 9:08:28 AM(UTC)
Frigidaire Affinity Washing Machine - Leaking only sometimes (Washer Repair)
by omf_24 2/24/2024 4:45:41 PM(UTC)
Stem question about Naytag 2-belt washing machine (Washer Repair)
by Hotrodjohn71 1/2/2024 7:50:48 AM(UTC)
Maytag Oasis HE Washing Machine (Washer Repair)
by Guest 12/8/2023 12:55:45 PM(UTC)
Whirlpool Washing Machine won't start/fill (Washer Repair)
by greekguy7 12/8/2023 4:53:34 AM(UTC)
whirlpool model wtw7300dw2 washing machine (Washer Repair)
by Guest 11/8/2023 9:27:17 AM(UTC)
MVWB965HC0 Washing Machine - Need Service Manual or Video to Replace Touchpad and Control Assembl (Washer Repair)
by Guest 10/30/2023 8:11:10 PM(UTC)
Best vintage, American made washing machines (Washer Repair)
by Guest 10/30/2023 5:27:34 AM(UTC)
Washing machine not washing clothes properly (Washer Repair)
by Guest 9/20/2023 11:56:24 AM(UTC)
Washing Machine fill with water but will not spin, rinse or agitate. (Washer Repair)
by jmaiso 9/1/2023 7:04:07 AM(UTC)
Washing machine do not complete the cycle (Washer Repair)
by Guest 8/16/2023 10:02:15 AM(UTC)
Mayag washing machine - possibly locked motor? (Washer Repair)
by crp0499 5/19/2023 3:02:19 AM(UTC)
