paul111
#1 Posted : Thursday, July 11, 2013 7:59:42 AM(UTC)
paul111
13 yr old side by side ge freezer side makes ice but the ice cream is soft. I read on this forum ice cream needs a lower temp (around 0) then ice.
I have:
cleaned coils.
removed back panel in freezer and no frost build-up on coils.
temp setting at lowest level for freezer
house typically in 70s although have had some hot days (no ac in house) last week but in the 70s for the past few days inside.
ref side appears to be ok and setting just below middle value of 5.
any suggestions appreciated.
paul111
#2 Posted : Thursday, July 11, 2013 8:09:20 AM(UTC)
paul111
Also: freezer door seal appears to be in good shape. no damage visible and can't feel any cold air leaking.
#3 Posted : Friday, July 12, 2013 2:47:25 AM(UTC)
Clean the condensing coils in the back, just might be your problem.
paul111
#4 Posted : Sunday, July 14, 2013 9:27:25 AM(UTC)
paul111
Thanks.
If the condenser coils are on the bottom, parts number :
Part Number WR84X188 (AP2076737) replaces 310000, AH309523, EA309523, PS309523, WR84X10018, WR84X0188.
Read more: GE WR84X188 Condenser Assembly - AppliancePartsPros.com
Appliance Parts Pros.com Discount Appliance Parts
I've given that a try. If I have the wrong item can you point me to the condenser coils. Other then a small access in the back on the bottom that provides access to the fan and condenser the unit's back is closed.
Do these ever lose a charge?
#5 Posted : Sunday, July 14, 2013 12:17:19 PM(UTC)
Remove the front panel under the door and clean the condensing coils there.
paul111
#6 Posted : Sunday, July 14, 2013 1:03:27 PM(UTC)
paul111
Thanks for update.
There was some buildup but not too significant. Cleaned that a earlier but still having an issue a few days later.
#7 Posted : Monday, July 15, 2013 12:45:46 AM(UTC)
Remove the back freezer panel and let the fridg run, if you only get partial frost on the evaporator coils, you have a refrigerant leak.
Whirlpool side by side freezer not cold enough (Refrigerator & Freezer Repair)
by sbww13 11/29/2014 10:51:07 AM(UTC)
Kenmore side by side freezer not cold enough (Refrigerator & Freezer Repair)
by SamB79 12/5/2012 12:11:05 PM(UTC)
