beccajayne
#1 Posted : Wednesday, June 26, 2013 3:15:04 PM(UTC)
beccajayne
Came home today and the "on indicator" light was lit on the range. No one had been home for hours so it wasn't in use and the burners/ovens weren't warm. I have checked all the dials, reset the fuse in the breaker box to see if resetting the range works and it is still lit. Any suggestions?
#2 Posted : Thursday, June 27, 2013 2:31:28 AM(UTC)
A model number may help others help you.
Find your model number - AppliancePartsPros.com
If the on light was for a surface element then odds are that an infinite (control) switch is bad.
beccajayne
#3 Posted : Thursday, June 27, 2013 6:30:46 AM(UTC)
beccajayne
Mer6755aaw
#4 Posted : Friday, June 28, 2013 1:49:02 AM(UTC)
Parts for Maytag MER6755AAW Range - AppliancePartsPros.com
See the attachment for the tech sheet
As you can see from the wiring diagram any of the infinite switches can control the on light, at least that is the most likely.
Unplug the unit.
Unplug the P wire at one of the switches.
Measure from P on the switch to L1 on the switch.
It should be infinite ohms.
When you find the one that is 0 ohms replace that switch.
File Attachment(s):
MER6755.pdf (717kb) downloaded 3 time(s).
lock on indicator light (Dishwasher Repair)
by cheyenne500 5/2/2013 1:48:48 PM(UTC)
on indicator lights stays on but burners still working (Oven Repair (including Ranges and Cooktops))
by SammyO 10/11/2012 6:13:01 AM(UTC)
Cooktop On Indicator light won't go off (Oven Repair (including Ranges and Cooktops))
by bwalker 11/22/2011 7:30:50 AM(UTC)
on indicator light will not turn off (Oven Repair (including Ranges and Cooktops))
by kamikaze126 8/20/2010 4:34:48 PM(UTC)
