kamikaze126
#1 Posted : Friday, August 20, 2010 4:34:48 PM(UTC)
kamikaze126
On indicator light will not turn off it is lit. All control switches in the off position which I have Quadruple checked. None of the elements are heating
kamikaze126
#2 Posted : Saturday, August 21, 2010 8:09:08 AM(UTC)
kamikaze126
I found the answer. Most likely the control switch. Check by removing wire to lite from each switch. reapply power if lite goes off replace that switch
