My replacement heater kit has just arrived. I read from the instructions that I may need RTV102 to seal the bell connector if I need to cut the wire. Will regular caulk for home repairs work? Originally Posted by: tjl ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) I removed the back panel today as instructed by Gene. The continuity test on the heater turned out to be open. The thermostat showed a low resistance (<1, freezer cold). I am pretty sure now the defrost heater is burned. I remember in another post somebody said both thermostat and the heater need to be changed. Do I have to change both?
It has to be waterproof.
hi Gene i have maytag ref. mod. # MZD2766GED AND i have frost buid up back of my freezer panel,fan is blowing good and can't find defrost timmer on break down diagram. did change the heater& therm. assy. part # ap4069923 and still no cool ref. any help thanks jaime
gene,
my freezer has been defrosting the food, not making ice and has build up of frost on the back panel of the freezer, the refrdge part has been cool but not cold like it has been.
thanks linda
Originally Posted by: Jaime Perez ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) hi Gene i have maytag ref. mod. # MZD2766GED AND i have frost buid up back of my freezer panel,fan is blowing good and can't find defrost timmer on break down diagram. did change the heater& therm. assy. part # ap4069923 and still no cool ref. any help thanks jaime You don't have a timer you have an electronic adaptive defrost control instead. Part 13 on this diagram. http://www.appliancepartspros.com/sect/9/e/j/9ej-ejjjjf.gif
Originally Posted by: LAWRENCE5 ![Go to Quoted Post Go to Quoted Post](/Themes/yafvision/icon_latest_reply.gif) gene, my freezer has been defrosting the food, not making ice and has build up of frost on the back panel of the freezer, the refrdge part has been cool but not cold like it has been. thanks linda We need your model number to really help but you probably have auto defrost failure Which consists of a defrost heater, a defrost thermostat and a defrost timer (or adaptive defrost control or motherboard etc.) Refrigerator Repair Guide: How To Fix a Refrigerator - ACME HOW TO.com
its gss201epaww. i looked at the diagram and cant figure out where to find it.
where is the defrost heater and thermostat??
