Hi what number should the black wire connect to on this timer? The unit came with the wire on #1 but the instructions seem to indicate that may not be correct. Thanks!
See the attachment for your tech sheet. Yours is cumulative run,. I believe it is Version 2 but double check this. Click on the below picture and watch the video. Part number: AP3110896
THIS FORUM IS DEAD!!!!!!! |
