RhondaS
#1 Posted : Thursday, January 10, 2013 3:00:13 PM(UTC)
RhondaS
My ice maker will not turn off automatically like it's supposed to. It just keeps making ice which overflows the bin. I thought the arm was working, but my son thinks it isn't. If that is the cause of the problem, can that part be easily replaced?
#2 Posted : Friday, January 11, 2013 2:22:55 PM(UTC)
Hello Rhonda,
If the bail arm in the upper position would not turn the ice maker off, the best and easiest solution is to replace the ice maker.
- The ice maker Part number: 5304458371
jfetrow
#3 Posted : Tuesday, May 28, 2013 9:38:53 AM(UTC)
jfetrow
Gene, how do you remove the ice maker unit? Mine isn't producing any ice at all (although the water dispense works), and I want to remove/replace/repair it. But I have no idea how to remove it. Can you give me any insight into that? Thanks in advance!
#4 Posted : Tuesday, May 28, 2013 12:10:20 PM(UTC)
What is the complete model of the refrigerator?
jfetrow
#5 Posted : Tuesday, May 28, 2013 2:06:43 PM(UTC)
jfetrow
FRS26LF7DSR
Do you need any more info than that? Thanks!
Oh, and is there any way to access the water tube that feeds water into the maker? I had to get ice that was blocking it, and I hear the mechanism trying to feed water into it, but it never works. I'm wondering if there's more ice beyond the point where I can reach it...
TracyH68
#6 Posted : Saturday, January 9, 2021 12:03:46 PM(UTC)
TracyH68
United States
I have this issue, the arm does not automatically go up when the bin is full. I can put it up and it will stop making ice and then I have to put it back down to start it making ice again.
Guest (4)
