I replaced transmission and cluch two months a go .it was not spinning and did not work right. worked fine after that now same thing .is it possible the cluch is gone again.we wash a lot of towles.
Groups: APP Team
Hi.
Have you checked the lid switch, the coupling, the drive block?
Simon.
Groups: APP Team
the tub spins but slow it all worked well after I installed the new transmission and clutch but it only worked for two months do you thing the clutch is gone again.all the lites flicker in my house when washer is running like it putting a strain on the motor. do you think I shoud replace drive block.
Groups: APP Team
Check the voltage drop, amps draw. May be it's your house supply. Drop the motor from the pump and transmission and check if it still gonna make the lights flicker. If it does - check the capacitor, replace the motor.
Simon.
