sleep
#1 Posted: : Tuesday, May 14, 2013 4:19:35 AM(UTC)
sleep
Front right burner - turn it on - ITS on HIGH!!!!
Turn it to low - ITS HIGH!!!
Which part do I replace and where can I find the service manual please??
Thanks in advance.
#2 Posted : Tuesday, May 14, 2013 3:46:46 PM(UTC)
Hello,
Sounds like the problem is a bad infinite switch for this burner. There is no service manual available for this range but you can easy access the part by removing the control panel rear cover. Do not forget to remove the power to the range first.
- The infinity switch Part number: 316436001
sleep
#3 Posted : Wednesday, May 15, 2013 6:56:58 AM(UTC)
sleep
Thank you!! I appreciate the help!
#4 Posted : Wednesday, May 15, 2013 4:55:29 PM(UTC)
sleep
#5 Posted : Thursday, May 16, 2013 3:28:08 PM(UTC)
sleep
I ordered the part here...wow! 5 - 7 days and its here the next day!
Impressed.
The old part 316021501 the black one 316021501
http://webmail.netins.net/Redir...ngwinds.com/sidepart.jpg
and the new 316436001 the white one
http://webmail.netins.net/Redir...ingwinds.com/connect.jpg
how do i wire it up?
sleep
#6 Posted : Thursday, May 16, 2013 3:29:55 PM(UTC)
sleep
UserPostedImage
UserPostedImage
sorry
#7 Posted : Friday, May 17, 2013 1:18:37 PM(UTC)
All terminals on the old and new switches are marked the same way (L1, L2, H1, H2). Just follow these marks.
sleep
#8 Posted : Tuesday, May 21, 2013 4:57:19 AM(UTC)
sleep
Got it Gene...I was comparing the patterns and the new part # numbering scheme is different
i.e. H1 (old part) goes to 5-H1 (new part)
Thanks....even had to use the chat person Nadene for help. Impressed!
#9 Posted : Tuesday, May 21, 2013 3:32:04 PM(UTC)
You are welcome. I'm glad you were able to fix it.
P.S. When I said "they are marked the same way" I meant L & H marks.
Guest (5)
