Front right burner - turn it on - ITS on HIGH!!!!
Turn it to low - ITS HIGH!!!
Which part do I replace and where can I find the service manual please??
Thanks in advance.
Hello, Sounds like the problem is a bad infinite switch for this burner. There is no service manual available for this range but you can easy access the part by removing the control panel rear cover. Do not forget to remove the power to the range first. - The infinity switch Part number: 316436001
Thank you!! I appreciate the help!
![UserPostedImage](http://gallopingwinds.com/sidepart.jpg) ![UserPostedImage](http://gallopingwinds.com/connect.jpg) sorry
All terminals on the old and new switches are marked the same way (L1, L2, H1, H2). Just follow these marks.
Got it Gene...I was comparing the patterns and the new part # numbering scheme is different
i.e. H1 (old part) goes to 5-H1 (new part)
Thanks....even had to use the chat person Nadene for help. Impressed!
You are welcome. I'm glad you were able to fix it.
Gene. P.S. When I said "they are marked the same way" I meant L & H marks.
