jackclarkjr
#1 Posted : Thursday, May 16, 2013 9:55:45 AM(UTC)
jackclarkjr
when setting temp on bake or convect bake, enter 350 degrees (for example), hit start, get "err" message and it drops temp to 260 degrees?
Joe / APP Team
#2 Posted : Thursday, May 16, 2013 10:49:47 AM(UTC)
Joe / APP Team
Jack, Check and make sure the control board has not been set for "Celsius" by accident. If that isn't the issue, please re post and supply a proper model number of your wall oven, so we can investigate further.
jackclarkjr
#3 Posted : Thursday, May 16, 2013 11:09:41 AM(UTC)
jackclarkjr
model is KESC307BWH3
How do i check celcius?
jackclarkjr
#4 Posted : Thursday, May 16, 2013 11:30:18 AM(UTC)
jackclarkjr
found another thread with info about changing to F from C. that did the trick! Thanks!:D
Joe / APP Team
#5 Posted : Thursday, May 16, 2013 11:43:08 AM(UTC)
Joe / APP Team
Jack, "Open the oven door, then press and hold BROIL pad for 5 seconds.(You will know you are in Celsius when "F" disappears.) To switch back to Fahrenheit, press "Broil" pad again for 5 seconds("F" will reappear.)"
260dgrs. C. is equal to 500dgrs. F. which is the top temperature range for a "Bake" cycle, and could create the ERR display code.
Joe / APP Team
#6 Posted : Thursday, May 16, 2013 11:45:53 AM(UTC)
Joe / APP Team
You're Welcome !!
