2 Pages12>
mledie
#1 Posted : Sunday, September 2, 2012 11:48:18 AM(UTC)
mledie
My GE fridge has been making a clicking sound for about a month. I notice the fan in the freezer will start and stop when it clicks until it will finally come on. The water/ice dispenser is also not working and when you hit it the lights on front will go out.
It has been working on and off but then last night it started making rapid clicking sounds and now it is silent will not cool in the fridge or freezer at all.
Looking through the forums I am trying to figure out if it just sounds like the motherboard or if the compressor might also be bad. Thanks for any help.
mledie
#2 Posted : Friday, September 7, 2012 6:23:45 AM(UTC)
mledie
I know I made a mistake and did a double post but does nobody have any answers for my problems here?
Simon / APP Team
#3 Posted : Friday, September 7, 2012 8:11:03 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
You need to replace the main control board
Part number: WR55X10942
It's located at the rear of the fridge under the metal plate.
Unplug the unit before doing anything and read the instructions, you may need to make some adjustments.
Here are the breakdown diagrams and Replacement parts for General Electric GSS25IFRFBB Refrigerator | AppliancePartsPros.com
Simon.
mledie
#4 Posted : Tuesday, September 18, 2012 3:22:14 PM(UTC)
mledie
Got the part and took maybe 10 mins to install it. Now everything works great! Even my water dispenser that had stopped working before the rest of the fridge is now dispensing again.
Thanks for the help.:)
Simon / APP Team
#5 Posted : Tuesday, September 18, 2012 6:30:11 PM(UTC)
Simon / APP Team
Groups: APP Team
You are welcome.
Simon.
daucoin11
#6 Posted : Tuesday, May 14, 2013 11:40:38 AM(UTC)
daucoin11
I replaced the board, actually twice, and it never gets cool. And there is clicking!
Any suggestions?
PLEASE
Simon / APP Team
#7 Posted : Wednesday, May 15, 2013 8:31:56 AM(UTC)
Simon / APP Team
Groups: APP Team
Hi.
Please provide the model number and more detailed describtion of the problem.
Also, if you don't mind the part number of the board you replaced.
Simon.
daucoin11
#8 Posted : Wednesday, May 15, 2013 9:55:00 AM(UTC)
daucoin11
Originally Posted by: Simon / APP Team Go to Quoted Post
Hi.
Simon.
Model # PFS22S1SBSS
Serial #THO42739
Board WR55X10942
Compressor wont start! AMP at relay goes to8.1
daucoin11
#9 Posted : Wednesday, May 15, 2013 9:55:55 AM(UTC)
daucoin11
Model # PFS22S1SBSS
Serial #THO42739
Board WR55X10942
Dave
Read more: http://forum.appliancepartspros...-cool.html#ixzz2TNwSw4mc
http://forum.appliancepartspros.com
Simon / APP Team
#10 Posted : Wednesday, May 15, 2013 11:00:19 AM(UTC)
Simon / APP Team
Groups: APP Team
Hello.
Check the continuity between three compressor's contacts and from one of them to the ground. If you read the resistance between the contacts and no continuity to the ground you may need to replace the start components
Part number: WR07X10097
If that doesn't help - you have a bad compressor.
Remember that the parts purchased from APP can be returned back even if you installed them.
Good luck.
Post the results.
Simon.
2 Pages12>
