3 Pages<123>
#11 Posted : Sunday, May 12, 2013 4:58:01 AM(UTC)
Sorry but I do not know what is happening here.
With the new board did the compressor and condenser fan come on?
FredericS
#12 Posted : Sunday, May 12, 2013 5:26:47 AM(UTC)
FredericS
Hi Denman,
Yes the compressor & fan did go on, but it was not very cold. I put my hand by the blower and the air was not very cold. After switching back to the old board, I could feel the air was colder at the vent. the temp came back down to 36 degrees when I checked it in the morning. And the freezer was also back to normal, the pops, ice cream sticks, etc.
I also put an outdoor thermometer in a glass of water to monitor the temp more closely, thinking maybe the regular fridge thermometer I have hanging in there is fluctuating to rapidly by measuring air temp.
Thanks,
Frederic
#13 Posted : Sunday, May 12, 2013 7:22:32 AM(UTC)
Something weird here.
As long as the compressor is on the unit should get as cold as the control dictates. once it hits set point it should then start to cycle to maintain that temperature.
There is no half way with the compressor. It is either full on or off.
FredericS
#14 Posted : Sunday, May 12, 2013 6:26:43 PM(UTC)
FredericS
After returning home, I checked he fridge and the temp was at approx 31 degrees. The thermometer in the glass has a film of ice on it. It seems the temp goes irrespective, regardless of what I set on the control panel. I set it higher for both the freezer and fridge compartments and checked it and it still stays the same, same 31 degrees.
Any thoughts?
#15 Posted : Monday, May 13, 2013 4:07:36 AM(UTC)
I am still not sure what is going on here.
With the replacement board you said that the compressor ran but the unit did not get cold enough and yet with the new board the compressor runs and it gets too cold.
I am missing something here and for the life of me cannot figure out what it is.
Did the evaporator/freezer fan run with the new board?
If not you may have received a bad board.
How long did you let it run with the new board installed?
You should let it run for at least 24 hours to see if the temperatures will hit set point and stabilize.
You could check the thermistors. The tech sheet says they should be about 2,700 ohms at room temperature.
FredericS
#16 Posted : Monday, May 13, 2013 7:10:07 AM(UTC)
FredericS
It sounded like the condenser was operating to me. The temp did drop a bit but not much, if I recall it went down to 55 and stayed there. Like I mentioned I put my hand near the vent and the ar did not seem that cold.
I left that board in for approx 5 hrs.
When I put in the old board back in to save the food. The temp went down pretty quickly to cold.
How do I check the thermistor? Can you guide me to a link?
FYI I ordered a replacement board in the event the new replacement board is defective. At least we can check that off the list when I try it.
#17 Posted : Monday, May 13, 2013 7:35:19 AM(UTC)
I would disconnect them at the control board and then measure their resistance.
Below is a chart of typical values. I do not have a chart you your specific devices.
http://www.google.ca/url?sa=t&rct=j&q=thermistor%20resistance&source=web&cd=9&sqi=2&ved=0CGgQFjAI&url=http%3A%2F%2Fwww.preconusa.com%2Foem%2Ftemperature%2FThermistor%2520temp-resist%2520chart.pdf&ei=kwaRUeLQOqbkyQHLxoDgBw&usg=AFQjCNF-fX9ZXgYTc17-zxc0NyBQVei9mw&cad=rja
FredericS
#18 Posted : Tuesday, May 14, 2013 6:14:49 AM(UTC)
FredericS
I'm sorry, I don't know what it looks like, so can't identify he part to test. Is this an expensive part, if not I can just replace it.
FYI: I had my fridge repaired last summer after a thunderstorm that knocked out the relay in the fridge. It would not turn on, after he replaced he relay the fridge would not turn the compressor off...I seemed and the freezing started happening. When I complained he said it was good it was working. So his is why I am troubleshooting it myself. The power surge may have affected something else.
The sat 24 hrs it has been ok running at 34 degrees consistently. Before that, the thermometer was in ice water. So I had to turn it off overnight. The pattern is it can work ok for a while and then it will go too cold and freeze everything or at other times go too warm and spoil the food.
I'm researching another repair place in town, as I need a back up plan if I can't fix the Robles myself. Let me know about the thermistor.
Also when I removed the control board I noticed there was a lead not plugged to anything...what is that for?
One other thing, he button that you push to do max cold does not light up on the original board ( which is installed does that indicated anything). It did on the new replacement board ( which did not work )
#19 Posted : Wednesday, May 15, 2013 1:27:18 AM(UTC)
See below click on the picture for more info.
According to the wiring diagram there should be two of them. One for the fresh food and one for the freezer.
I can only find one of them in the parts breakdown item 5 in the Refrigerator Liner section.
Looks like they plug into P4 on the board.
[COLOR="Blue"]
The sat 24 hrs it has been ok running at 34 degrees consistently. [/COLOR]
This is too cold it should hold the fresh food section around 40 degrees F.
[COLOR="Blue"]
Also when I removed the control board I noticed there was a lead not plugged to anything...what is that for?[/COLOR]
I do not know. I cannot see the part side of the board good enough to make out the plug designations.
Something is either wrong with the wiring diagram or the parts breakdown as the diagram shows 2 thermistors but in the breakdown I can only find one.
P1 is for defrost parts, air baffle position switch, compressor and it's fan and power to the board.
P2 is for the lights, evaporator fan, air baffle motor and ice maker
P4 is for the thermistors.
The thermistors do go bad but it is very, very rare that they will go intermittent which your would have to do to give the symptoms you describe.
I am still leaning towards you received a bad replacement board.
Or the replacement board and the thermistor are bad.
Part number: AP3745265
I was able to find a chart for the thermistor resistances.
It is for a different fridge but the thermistors are the same
Temperature F / Resistance(Ohm)
77.0 / 2700
50.0 / 5348
45.0 / 6033
40.0 / 6989
35.0 / 7916
32.0 / 8750 Freezing point
30.2 / 9216
25.0 / 10483
20.0 / 12269
15.0 / 14019
10.0 / 16497
5.0 / 19474
0. 0 / 22417
–5.0 / 27402
–10.0 / 31717
–15.0 / 37922
Yes it may be time to get in a pro.
I can only summarize what I think.
The unit gets too cold. That tells you that the compressor/sealed system is OK.
In your original post you said you checked the damper so it is opening and closing (not stuck).
So in my opinion it is a temperature control issue and the only parts that do this is the control board and the thermistors. The control board is more likely to go intermittent.
FredericS
#20 Posted : Wednesday, May 15, 2013 5:46:50 AM(UTC)
FredericS
Thank you for the comprehensive detailing. Let's see what happens with the new board. Based on what you said it looks like a good prospect.
When I checked the damper, I looked to be sure it was blowing air. I did not check to see that it was sticky or stuck. Maybe I should follow up on that too.
Thanks again, I should be receiving the new board soon. I'll let you know how it works out. So far the fridge is holding a constant temp (although too cold) it is not freezing anything just yet.
Guest (10)
3 Pages<123>
