Just wanted to update you. I replaced the board and ran the unit for two days at he default setting 0 F freezer and 38F fridge. After the second day things some things froze.
Than I set the thermostat to the highest settings in both the freezer 5F & 40F in the. Fridge and the temps are now within a normal range and nothing freezes in the fridge and the freezer seems good to go as well. It has been 3 or 4 days now and all seems fine. I guess the first replacement board was bad, as he compressors never did go on.
Let me know way you think
Sounds like you found the problem but only time will tell. I will keep my fingers crossed.
One thing you may want to consider is to get a 1,000 joule surge protector for the fridge especially if you have power outages or if the fridge is not on it's own line. These are available at Home Depot etc. |
THIS FORUM IS DEAD!!!!!!! |
That's a good thought, as the problem initially manifested itself due to an electrical storm. Incidentally, with he spring weather we had one last night and I was worried about the fridge circuit board. So far all seems OK. I will go to Lowes today before he next storm hits.
Thanks again for all your help
